Help required to create a certificate
I am receiving this warning when I try to install this api on a Windows 10 PC.
This PC contains a database and is connected to an FTP server and clients connect externally to the FTP.
This PC is going to be published after installing this API. I created a CSR using mmc command in windows using this guide: https://www.entrust.com/knowledgebase/ssl/how-to-generate-certificate-signing-request-using-microsoft-management-console-mmc-on-windows-2012.
I want to now get the SSL certificate.
What is the next step? I am not an expert but I am trying to learn to get this task done.
Thank you so much!
What warning? A dialog box asking for a certificate and key isn't a warning of anything.
I'd suggest you start by reading the docs. Start here:
Please continue in your previous thread instead of opening a similar thread:
