Help regarding use of LE certs for Prosody
Prosody is my preferred XMPP server.
I use acme.sh to issue LE certificates. The folder containing those certificates has the following files:
ca.cer
fullchain.cer
otx82wn9xnzcygap6bsc.duckdns.org.cer
otx82wn9xnzcygap6bsc.duckdns.org.conf
otx82wn9xnzcygap6bsc.duckdns.org.csr
otx82wn9xnzcygap6bsc.duckdns.org.csr.conf
otx82wn9xnzcygap6bsc.duckdns.org.key
Prosody configuration needs a key and a certificate file. Which of these should I point it to?
Thanks for the help!
Use these files:
Key:
Certificate:
Got it. Thanks so much!
