Hello!
Can you advice me with configure TLS Exim + LE:
for MAIN_TLS_PRIVATE_KEY i use live/domain.tld/privkey.pem
But for MAIN_TLS_CERTIFICATE i need use live/domain.tld/cert.pem or live/domain.tld/fullchain.pem ?
thx.
Hello!
thx.
Docs seem to indicate tls_certificate
would require fullchain.pem:
The file named by tls_certificate may contain more than one certificate. This is useful in the case where the certificate that is being sent is validated by an intermediate certificate which the other end does not have.
Not sure what the difference between tls_certificate
and MAIN_TLS_CERTIFICATE
is, but I would expect it to be similar.
