Hi Friends!
This afternoon (in the morning this problem was not there), running Dino XMPP Linux client for connecting to my own Prosody server 0.11.5-1 hosted on Debian9, obtain the error:
"Unable to connect to server, TLS certificate not valid".
So deepening the issue, I check the certificate on server side and all seems ok, so I run the testssl.sh tool that tell me: "Chain of trust NOT ok".
I'm using "acme.sh" as Let's Encrypt client.
Here the output of testssl.sh:
Testing protocols via sockets
SSLv2 not offered (OK)
SSLv3 not offered (OK)
TLS 1 offered (deprecated)
TLS 1.1 offered (deprecated)
TLS 1.2 offered (OK)
TLS 1.3 offered (OK): final
Testing cipher categories
NULL ciphers (no encryption) not offered (OK)
Anonymous NULL Ciphers (no authentication) not offered (OK)
Export ciphers (w/o ADH+NULL) not offered (OK)
LOW: 64 Bit + DES, RC[2,4] (w/o export) not offered (OK)
Triple DES Ciphers / IDEA not offered
Obsolete CBC ciphers (AES, ARIA etc.) offered
Strong encryption (AEAD ciphers) offered (OK)
Testing robust (perfect) forward secrecy, (P)FS -- omitting Null Authentication/Encryption, 3DES, RC4
PFS is offered (OK) TLS_AES_256_GCM_SHA384 TLS_CHACHA20_POLY1305_SHA256 ECDHE-RSA-AES256-GCM-SHA384 ECDHE-RSA-AES256-SHA384 ECDHE-RSA-AES256-SHA
ECDHE-RSA-CHACHA20-POLY1305 ECDHE-RSA-CAMELLIA256-SHA384 ECDHE-ARIA256-GCM-SHA384 TLS_AES_128_GCM_SHA256
ECDHE-RSA-AES128-GCM-SHA256 ECDHE-RSA-AES128-SHA256 ECDHE-RSA-AES128-SHA ECDHE-RSA-CAMELLIA128-SHA256 ECDHE-ARIA128-GCM-SHA256
Elliptic curves offered: prime256v1 secp384r1 secp521r1
Testing server preferences
Has server cipher order? yes (OK) -- TLS 1.3 and below
Negotiated protocol TLSv1.3
Negotiated cipher TLS_AES_256_GCM_SHA384, 256 bit ECDH (P-256)
Cipher order
TLSv1: ECDHE-RSA-AES256-SHA ECDHE-RSA-AES128-SHA AES256-SHA CAMELLIA256-SHA AES128-SHA CAMELLIA128-SHA
TLSv1.1: ECDHE-RSA-AES256-SHA ECDHE-RSA-AES128-SHA AES256-SHA CAMELLIA256-SHA AES128-SHA CAMELLIA128-SHA
TLSv1.2: ECDHE-RSA-AES256-GCM-SHA384 ECDHE-RSA-CHACHA20-POLY1305 ECDHE-ARIA256-GCM-SHA384 ECDHE-RSA-AES128-GCM-SHA256 ECDHE-ARIA128-GCM-SHA256
ECDHE-RSA-AES256-SHA384 ECDHE-RSA-CAMELLIA256-SHA384 ECDHE-RSA-AES128-SHA256 ECDHE-RSA-CAMELLIA128-SHA256 ECDHE-RSA-AES256-SHA
ECDHE-RSA-AES128-SHA AES256-GCM-SHA384 AES256-CCM8 AES256-CCM ARIA256-GCM-SHA384 AES128-GCM-SHA256 AES128-CCM8 AES128-CCM ARIA128-GCM-SHA256
AES256-SHA256 CAMELLIA256-SHA256 AES128-SHA256 CAMELLIA128-SHA256 AES256-SHA CAMELLIA256-SHA AES128-SHA CAMELLIA128-SHA
TLSv1.3: TLS_AES_256_GCM_SHA384 TLS_CHACHA20_POLY1305_SHA256 TLS_AES_128_GCM_SHA256
Testing server defaults (Server Hello)
TLS extensions (standard) "renegotiation info/#65281" "EC point formats/#11" "supported versions/#43" "key share/#51" "supported_groups/#10"
"max fragment length/#1" "encrypt-then-mac/#22" "extended master secret/#23"
Session Ticket RFC 5077 hint no -- no lifetime advertised
SSL Session ID support yes
Session Resumption Tickets no, ID: no
TLS clock skew Random values, no fingerprinting possible
Signature Algorithm SHA256 with RSA
Server key size RSA 2048 bits
Server key usage Digital Signature, Key Encipherment
Server extended key usage TLS Web Server Authentication, TLS Web Client Authentication
Serial / Fingerprints 0429AF3DA5AD9F545FB00FB3DD1815C89D28 / SHA1 3EDB59C827E973BF2148331F5955E45E9B9D671F
SHA256 D9022C2855CECB15EC2DD9C785FF4B6844426F2E94C1F5D4727616FF915AF20B
Common Name (CN) server.3x1t.org
subjectAltName (SAN) 3x1t.org attivazione.3x1t.org autoconfig.3x1t.org autodiscover.3x1t.org cloud.3x1t.org collabora.3x1t.org conference.3x1t.org
converse.3x1t.org lists.3x1t.org mail.3x1t.org server.3x1t.org smtp.3x1t.org turn.3x1t.org upload.3x1t.org upload.server.3x1t.org
www.3x1t.org www.converse.3x1t.org
Issuer R3 (Let's Encrypt from US)
Trust (hostname) Ok via SAN (same w/o SNI)
Chain of trust NOT ok (expired)
EV cert (experimental) no
ETS/"eTLS", visibility info not present
Certificate Validity (UTC) 88 >= 60 days (2021-09-28 23:23 --> 2021-12-27 22:23)
# of certificates provided 3
Certificate Revocation List --
OCSP URI http://r3.o.lencr.org
OCSP stapling not offered
OCSP must staple extension --
DNS CAA RR (experimental) not offered
Certificate Transparency yes (certificate extension)
Testing vulnerabilities
Heartbleed (CVE-2014-0160) not vulnerable (OK), no heartbeat extension
CCS (CVE-2014-0224) not vulnerable (OK)
ROBOT not vulnerable (OK)
Secure Renegotiation (RFC 5746) supported (OK)
Secure Client-Initiated Renegotiation VULNERABLE (NOT ok), potential DoS threat
CRIME, TLS (CVE-2012-4929) not vulnerable (OK) (not using HTTP anyway)
POODLE, SSL (CVE-2014-3566) not vulnerable (OK), no SSLv3 support
TLS_FALLBACK_SCSV (RFC 7507) Downgrade attack prevention supported (OK)
SWEET32 (CVE-2016-2183, CVE-2016-6329) not vulnerable (OK)
FREAK (CVE-2015-0204) not vulnerable (OK)
DROWN (CVE-2016-0800, CVE-2016-0703) not vulnerable on this host and port (OK)
make sure you don't use this certificate elsewhere with SSLv2 enabled services
https://censys.io/ipv4?q=D9022C2855CECB15EC2DD9C785FF4B6844426F2E94C1F5D4727616FF915AF20B could help you to find out
LOGJAM (CVE-2015-4000), experimental not vulnerable (OK): no DH EXPORT ciphers, no DH key detected with <= TLS 1.2
BEAST (CVE-2011-3389) TLS1: ECDHE-RSA-AES256-SHA ECDHE-RSA-AES128-SHA AES256-SHA CAMELLIA256-SHA AES128-SHA CAMELLIA128-SHA
VULNERABLE -- but also supports higher protocols TLSv1.1 TLSv1.2 (likely mitigated)
LUCKY13 (CVE-2013-0169), experimental potentially VULNERABLE, uses cipher block chaining (CBC) ciphers with TLS. Check patches
RC4 (CVE-2013-2566, CVE-2015-2808) no RC4 ciphers detected (OK)
Testing 370 ciphers via OpenSSL plus sockets against the server, ordered by encryption strength
Hexcode Cipher Suite Name (OpenSSL) KeyExch. Encryption Bits Cipher Suite Name (IANA/RFC)
x1302 TLS_AES_256_GCM_SHA384 ECDH 256 AESGCM 256 TLS_AES_256_GCM_SHA384
x1303 TLS_CHACHA20_POLY1305_SHA256 ECDH 256 ChaCha20 256 TLS_CHACHA20_POLY1305_SHA256
xc030 ECDHE-RSA-AES256-GCM-SHA384 ECDH 384 AESGCM 256 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
xc028 ECDHE-RSA-AES256-SHA384 ECDH 384 AES 256 TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
xc014 ECDHE-RSA-AES256-SHA ECDH 384 AES 256 TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA
xcca8 ECDHE-RSA-CHACHA20-POLY1305 ECDH 384 ChaCha20 256 TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256
xc077 ECDHE-RSA-CAMELLIA256-SHA384 ECDH 384 Camellia 256 TLS_ECDHE_RSA_WITH_CAMELLIA_256_CBC_SHA384
x9d AES256-GCM-SHA384 RSA AESGCM 256 TLS_RSA_WITH_AES_256_GCM_SHA384
xc0a1 AES256-CCM8 RSA AESCCM8 256 TLS_RSA_WITH_AES_256_CCM_8
xc09d AES256-CCM RSA AESCCM 256 TLS_RSA_WITH_AES_256_CCM
x3d AES256-SHA256 RSA AES 256 TLS_RSA_WITH_AES_256_CBC_SHA256
x35 AES256-SHA RSA AES 256 TLS_RSA_WITH_AES_256_CBC_SHA
xc0 CAMELLIA256-SHA256 RSA Camellia 256 TLS_RSA_WITH_CAMELLIA_256_CBC_SHA256
x84 CAMELLIA256-SHA RSA Camellia 256 TLS_RSA_WITH_CAMELLIA_256_CBC_SHA
xc051 ARIA256-GCM-SHA384 RSA ARIAGCM 256 TLS_RSA_WITH_ARIA_256_GCM_SHA384
xc061 ECDHE-ARIA256-GCM-SHA384 ECDH 384 ARIAGCM 256 TLS_ECDHE_RSA_WITH_ARIA_256_GCM_SHA384
x1301 TLS_AES_128_GCM_SHA256 ECDH 256 AESGCM 128 TLS_AES_128_GCM_SHA256
xc02f ECDHE-RSA-AES128-GCM-SHA256 ECDH 384 AESGCM 128 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
xc027 ECDHE-RSA-AES128-SHA256 ECDH 384 AES 128 TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
xc013 ECDHE-RSA-AES128-SHA ECDH 384 AES 128 TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA
xc0a0 AES128-CCM8 RSA AESCCM8 128 TLS_RSA_WITH_AES_128_CCM_8
xc09c AES128-CCM RSA AESCCM 128 TLS_RSA_WITH_AES_128_CCM
xc076 ECDHE-RSA-CAMELLIA128-SHA256 ECDH 384 Camellia 128 TLS_ECDHE_RSA_WITH_CAMELLIA_128_CBC_SHA256
x9c AES128-GCM-SHA256 RSA AESGCM 128 TLS_RSA_WITH_AES_128_GCM_SHA256
x3c AES128-SHA256 RSA AES 128 TLS_RSA_WITH_AES_128_CBC_SHA256
x2f AES128-SHA RSA AES 128 TLS_RSA_WITH_AES_128_CBC_SHA
xba CAMELLIA128-SHA256 RSA Camellia 128 TLS_RSA_WITH_CAMELLIA_128_CBC_SHA256
x41 CAMELLIA128-SHA RSA Camellia 128 TLS_RSA_WITH_CAMELLIA_128_CBC_SHA
xc050 ARIA128-GCM-SHA256 RSA ARIAGCM 128 TLS_RSA_WITH_ARIA_128_GCM_SHA256
xc060 ECDHE-ARIA128-GCM-SHA256 ECDH 384 ARIAGCM 128 TLS_ECDHE_RSA_WITH_ARIA_128_GCM_SHA256
Running client simulations via sockets
Android 8.1 (native) TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 384 bit ECDH (P-384)
Android 9.0 (native) TLSv1.3 TLS_AES_256_GCM_SHA384, 384 bit ECDH (P-384)
Android 10.0 (native) TLSv1.3 TLS_AES_256_GCM_SHA384, 384 bit ECDH (P-384)
Java 6u45 TLSv1.0 AES128-SHA, No FS
Java 7u25 TLSv1.0 ECDHE-RSA-AES128-SHA, 384 bit ECDH (P-384)
Java 8u161 TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 384 bit ECDH (P-384)
Java 11.0.2 (OpenJDK) TLSv1.3 TLS_AES_256_GCM_SHA384, 256 bit ECDH (P-256)
Java 12.0.1 (OpenJDK) TLSv1.3 TLS_AES_256_GCM_SHA384, 256 bit ECDH (P-256)
OpenSSL 1.0.2e TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 384 bit ECDH (P-384)
OpenSSL 1.1.0l (Debian) TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 384 bit ECDH (P-384)
OpenSSL 1.1.1d (Debian) TLSv1.3 TLS_AES_256_GCM_SHA384, 384 bit ECDH (P-384)
Done 2021-09-30 17:51:12 [ 175s] -->> 3x1t.org:5222 (3x1t.org) <<--
Could you give me any suggestion about?
Many thanks!
davide
