Help regarding steps to renew SSL certificate
www.egangaa.net had a SSL certificate from ‘let’s encrypt’ and got expired on 8th April 2019 that is yesterday. Now all our production services are hitting errror, how do we go about renewing the same at the earliest.
thanks
Egangaa team
Hi @ygt, welcome to the Let’s Encrypt community forum :wave:
My domain is: www.egangaa.net
I ran this command: sudo certbot certonly
It produced this output: Failed authorization procedure. www.egangaa.net (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.egangaa.net/.well-known/acme-challenge/l9iZKZqgIIdFIbxE0dkgxLaAAOQVo_zICtwnWOC7wug [95.216.204.216]: “<!doctype html><html lang=“en”>HTTP Status 404 \u2013 Not Found<style type=“text/css”>h1 {font-family:Tahoma,A”
My web server is (include version): Apache Tomcat (8.5.37.0)
The operating system my web server runs on is (include version): Ubuntu 16.04
My hosting provider, if applicable, is: Hetzner
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.28.0
Hi @ygt
there are some checks ~2 hours old ( https://check-your-website.server-daten.de/?q=egangaa.net ):
Your port 80 is open, your Tomcat answers. Tomcat is a little bit "special".
So find your tomcat webroot. Then use it.
certbot -a webroot certonly -w yourTomcatWebroot -d egangaa.net -d www.egangaa.net
