Need help getting SSL renewed
Hello,
My domain is: sridhar.blog
I ran this command: letsencrypt renew
Processing /etc/letsencrypt/renewal/minimum-soliloquy.wpdemos.co.conf
Processing /etc/letsencrypt/renewal/wparena.wpdemos.co.conf
Processing /etc/letsencrypt/renewal/hooks.wpdemos.co.conf
Processing /etc/letsencrypt/renewal/sridhar.blog.conf
2018-05-17 05:44:42,709:WARNING:letsencrypt.cli:Attempting to renew cert from /etc/letsencrypt/renewal/sridhar.blog.conf produced an unexpected error: Failed authorization procedure. www.sridhar.blog (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.sridhar.blog/.well-known/acme-challenge/5elk63lrr1TdLTDHsTD0W2HdrYrhI5_EFQWN9SL8er8: "<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title></head><body>
<h1>Not Found</h1>
<p", sridhar.blog (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://sridhar.blog/.well-known/acme-challenge/9DtaQXUF4dcUxypaFXzWLLBlcfrZVLfyoslNMa88iyo: "<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<h1>Not Found</h1>
<p". Skipping.
Processing /etc/letsencrypt/renewal/slideout.wpdemos.co.conf
  /etc/letsencrypt/live/minimum-soliloquy.wpdemos.co/fullchain.pem (skipped)
  /etc/letsencrypt/live/wparena.wpdemos.co/fullchain.pem (skipped)
  /etc/letsencrypt/live/hooks.wpdemos.co/fullchain.pem (skipped)
  /etc/letsencrypt/live/slideout.wpdemos.co/fullchain.pem (skipped)
  /etc/letsencrypt/live/sridhar.blog/fullchain.pem (failure)
   Domain: www.sridhar.blog
   Type:   unauthorized
   Detail: Invalid response from http://www.sridhar.blog/.well-known
   <html><head>
   </head><body>
   <h1>Not Found</h1>
   <p"
   Domain: sridhar.blog
   Type:   unauthorized
   Detail: Invalid response from http://sridhar.blog/.well-known/acme-
   <html><head>
   </head><body>
   <h1>Not Found</h1>
   <p"
My web server is (include version): nginx/1.13.10 (output of nginx-sp -v)
The operating system my web server runs on is (include version): Ubuntu 16.04
My hosting provider is: DigitalOcean
I can login to a root shell on my machine: Yes
I’m using a control panel to manage my site: Free ServerPilot account
I have also tried to issue a new SSL certificate via https://github.com/lesaff/serverpilot-letsencrypt but I continue to get “Your connection is not private” warning in the browser.
You sure about that?
$ curl -X GET -I sridhar.blog/.well-known/acme-challenge/
HTTP/1.1 200 OK
Date: Thu, 17 May 2018 06:20:44 GMT
Server: Apache
Upgrade: h2,h2c
Connection: Upgrade
Content-Length: 654
Content-Type: text/html;charset=ISO-8859-1
Some or all of your other domains are on nginx, but the one that's failing is definitely pointing somewhere else, to an entirely different IP address in fact.
