Hello all!
I’m using Docker env with exposed 80, 443 port.
And I tested standalone and nginx plugin command for certbot.
But all of them doesn’t work for me.
So I tried with --manual option for debug.
As i understand certbot wants me to make url like “http://demo.lomin.ai/.well-known/acme-challenge/HHv-e7A6inc_lGwWqyfrzBfEZRm2LlLHWsIbpEDaEEw” to response ‘HHv-e7A6inc_lGwWqyfrzBfEZRm2LlLHWsIbpEDaEEw.9QWlxiDYoLlCDmfW3iNIOr5c9QYGGyBwfEZdCELrlKo’.
So I make the url with the key even I can access by myself.
But the http-01 challenge is not possible to me…
Anybody have idea to solve it?
demo.lomin.ai
certbot-auto certonly --manual
Press Enter to Continue
Waiting for verification…
Failed authorization procedure. demo.lomin.ai (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://demo.lomin.ai/.well-known/acme-challenge/EWbLNaAWwRZGM1UCqSvbIIxFFaoH09wPUEwVuYucCb0: Timeout during connect (likely firewall problem)
- The following errors were reported by the server:Domain: demo.lomin.ai
Type: connection
Detail: Fetching
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
that you are serving files from the webroot path you provided. - Your account credentials have been saved in your Certbot
nginx version: nginx/1.13.12
PRETTY_NAME=“Debian GNU/Linux 9 (stretch)”
NAME=“Debian GNU/Linux”
VERSION_ID=“9”
VERSION=“9 (stretch)”
ID=debian
AWS route 53.
yes.
no
