Help for certbot itself cannot be provided until it is installed
http:wolfiep.com
wget https://dl.eff.org/certbot-auto && chmod a+x certbot-auto
then…
./certbot-auto certonly --webroot -w /var/www/html/ -d wolfiep.com -d www.wolfiep.com
Requesting to rerun ./certbot-auto with root privileges…
Usage: certbot-auto [OPTIONS]
A self-updating wrapper script for the Certbot ACME client. When run, updates
to both this script and certbot will be downloaded and installed. After
ensuring you have the latest versions installed, certbot will be invoked with
all arguments you have provided.
Help for certbot itself cannot be provided until it is installed.
–debug attempt experimental installation
-h, --help print this help
-n, --non-interactive, --noninteractive run without asking for user input
–no-bootstrap do not install OS dependencies
–no-self-upgrade do not download updates
–os-packages-only install OS dependencies and exit
–install-only install certbot, upgrade if needed, and exit
-v, --verbose provide more output
-q, --quiet provide only update/error output;
implies --non-interactive
All arguments are accepted and forwarded to the Certbot client when run.
My webserver is a linux google cloud wordpress click to deploy
Yes
That’s weird.
Try
sudo ./certbot-auto
and then your original command again.
Thanks _az this went through although it carried on prompting me further I ended up with this and am unsure whether this is normal
We were unable to find a vhost with a ServerName or Address of www.wolfiep.com.
Which virtual host would you like to choose?
(note: conf files with multiple vhosts are not yet supported)
1: wordpress.conf | | | Enabled
2: wordpress-le-ssl.conf | wolfiep.com | HTTPS | Enabled
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel):
many thanks!
You have an existing certificate that has exactly the same domains or certificate name you requested and isn’t close to expiry.
(ref: /etc/letsencrypt/renewal/wolfiep.com.conf)
What would you like to do?
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 1
Created an SSL vhost at /etc/apache2/sites-available/wordpress-le-ssl.conf
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Deploying Certificate to VirtualHost /etc/apache2/sites-available/wordpress-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/wordpress-le-ssl.conf
