My domain is: mail.thesourceb2b.com
I ran this command: certbot certonly --webroot --dry-run -w /var/www/html -d mail.thesourceb2b.com
root@mail:~# apt install certbot
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
python3-acme python3-certbot python3-configargparse python3-configobj python3-future python3-icu
python3-josepy python3-mock python3-openssl python3-parsedatetime python3-pbr
python3-requests-toolbelt python3-rfc3339 python3-tz python3-zope.component python3-zope.event
python3-zope.hookable python3-zope.interface
Suggested packages:
python3-certbot-apache python3-certbot-nginx python-certbot-doc python-acme-doc
python-configobj-doc python-future-doc python-mock-doc python-openssl-doc python3-openssl-dbg
The following NEW packages will be installed:
certbot python3-acme python3-certbot python3-configargparse python3-configobj python3-future
python3-icu python3-josepy python3-mock python3-openssl python3-parsedatetime python3-pbr
0 upgraded, 19 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,315 kB of archives.
Preparing to unpack .../17-python3-icu_2.4.2-0ubuntu3_amd64.deb ...
Unpacking python3-icu (2.4.2-0ubuntu3) ...
Selecting previously unselected package certbot.
Preparing to unpack .../18-certbot_0.40.0-1ubuntu0.1_all.deb ...
Unpacking certbot (0.40.0-1ubuntu0.1) ...
Setting up python3-configargparse (0.13.0-2) ...
Setting up python3-requests-toolbelt (0.8.0-1.1) ...
Setting up python3-icu (2.4.2-0ubuntu3) ...
Setting up python3-zope.event (4.4-2build1) ...
Setting up python3-zope.interface (4.7.1-1) ...
Setting up python3-pbr (5.4.5-0ubuntu1) ...
update-alternatives: using /usr/bin/python3-pbr to provide /usr/bin/pbr (pbr) in auto mode
Setting up python3-openssl (19.0.0-1build1) ...
Setting up python3-tz (2019.3-1) ...
Setting up python3-mock (3.0.5-1build1) ...
Setting up python3-zope.hookable (5.0.0-1build1) ...
Setting up python3-configobj (5.0.6-4) ...
Setting up python3-josepy (1.2.0-2) ...
Setting up python3-future (0.18.2-2) ...
update-alternatives: using /usr/bin/python3-futurize to provide /usr/bin/futurize (futurize) in auto mode
update-alternatives: using /usr/bin/python3-pasteurize to provide /usr/bin/pasteurize (pasteurize) in auto mode
Setting up python3-rfc3339 (1.1-2) ...
Setting up python3-parsedatetime (2.4-5) ...
Setting up python3-zope.component (4.3.0-3) ...
Setting up python3-acme (1.1.0-1) ...
Setting up python3-certbot (0.40.0-1ubuntu0.1) ...
Setting up certbot (0.40.0-1ubuntu0.1) ...
Created symlink /etc/systemd/system/timers.target.wants/certbot.timer → /lib/systemd/system/certbot.timer.
Processing triggers for man-db (2.9.1-1) ...
root@mail:~# certbot certonly --webroot --dry-run -w /var/www/html -d mail.thesourceb2b.com
Enter email address (used for urgent renewal and security notices) (Enter 'c' to
cancel): serveradmin@thesourceb2b.com
agree in order to register with the ACME server at
https://acme-staging-v02.api.letsencrypt.org/directory
(A)gree/(C)ancel: A
An unexpected error occurred:
The server experienced an internal error :: Error creating new order
root@mail:~# An unexpected error occurred:
An: command not found
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: Contabo VPS Server
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
