Help Creating Certificate Manual Mode, don't know where to put
My domain is: bdnetbreeze.blackdragonnetworks.com
I ran this command: certbot run -d bdnetbreeze.blackdragonnetworks.com --force-renewal
It produced this output:Saving debug log to /var/log/letsencrypt/letsencrypt.log
http-01 challenge for bdnetbreeze.blackdragonnetworks.com
Using default addresses 80 and [::]:80 ipv6only=on for authentication.
Challenge failed for domain bdnetbreeze.blackdragonnetworks.com
My web server is (include version): Apache/2.4.6 (CentOS)
The operating system my web server runs on is (include version): Centos 7
My hosting provider, if applicable, is: vul
That adds nothing to the equation - please don't use it without a real need.
Please show the output of:
apachectl -t -D DUMP_VHOSTS
Certbot thinks your webserver is nginx.
The webserver responding on that domain is Apache.
Does this domain definitely point to the right server?
Does running Certbot with the Apache plugin instead help?
sudo certbot --apache -d bdnetbreeze.blackdragonnetworks.com
Passing arguments to httpd using apachectl is no longer supported.
You can only start/stop/restart httpd using this script.
If you want to pass extra arguments to httpd, edit the
/etc/sysconfig/httpd config file.
VirtualHost configuration:
*:80 bdnetbreeze.blackdragonnetworks.com (/etc/httpd/conf.d/le-redirect-bdnetbreeze.blackdragonnetworks.com.conf:1)
[root@bdnetbreeze ~]#
Job for httpd.service failed because the control process exited with error code. See "systemctl status httpd.service" and "journalctl -xe" for details.
Job for httpd.service invalid.
Unable to restart apache using ['apachectl', 'graceful']
Error while running apachectl restart.
Encountered exception during recovery: MisconfigurationError: Error while running apachectl restart.
I finally got the system to work. This is Breezeview a TELRAD product working on a CENTOS 7 Server It is a nginx it a 443 forwarded to port 8082.
[root@bdnetbreeze /]# certbot --nginx -d bdnetbreeze.blackdragonnetworks.com
Deploying Certificate to VirtualHost /etc/nginx/nginx.conf
No matching insecure server blocks listening on port 80 found.
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains:
https://bdnetbreeze.blackdragonnetworks.com
    /etc/letsencrypt/live/bdnetbreeze.blackdragonnetworks.com/fullchain.pem
    /etc/letsencrypt/live/bdnetbreeze.blackdragonnetworks.com/privkey.pem
    Your cert will expire on 2022-07-19. To obtain a new or tweaked
    with the "certonly" option. To non-interactively renew all of
    Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
    Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
