My domain is: collisdesign.com.au
I ran this command: certbot renew [dry run, even new install]
The operating system my web server runs on is (include version): MAC [mojave 10.14.6]
My hosting provider, if applicable, is: My MacMini
I can login to a root shell on my machine (yes or no, or I don't know): Yes[?]
No
certbot 0.32.0
MY NOTES: Using LE since 2019 - renew every 90 days with no issues until now [Aug 2022]. From forum search and Mac Terminal response, ".well-known/acme-challenge/" is a smoking gun. Have even created this hidden folder manually.
Forum posts mention adding "skip challenge requests" to server config?
Before I go down the rabbit hole, hopefully someone here can assist with a fix.
Also ran in terminal: apachectl -S
AH00526: Syntax error on line 25 of /private/etc/apache2/extra/httpd-vhosts-le-ssl.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/collisdesign.com.au/fullchain.pem' does not exist or is empty
Have you changed anything in your NAT or port-forwarding or MAC? Because these are the response headers from your domain. It looks like WebDAV is now responding to requests on port 80 (http) and not Apache.
...thanks Mike for the reply [at least someone].
Had WebDAVNav Server running whilst Apache/LE SSL was not working.
fyi, absolutely no changes have been made prior to this issue - this MacMini sits in the corner doing nothing except running as a web server/internal file server/web development server.
Anyway, long story short... SOLUTION FIX: Forget LE as provider of SSL Cert, moved over to, now using ZeroSSL who also provide a 90 day $0 cost option plus have a super simple how-to guide to install certs on Apache. Job Done.
The apachectl -S identified a missing certificate file. That would have prevented Apache starting.
Your history showed you renewed certs on date of expiry or day before. Generally that's done with 30 days remaining to ensure enough time to resolve problems. You should probably change that for ZeroSSL too.
Your comment about the acme-challenge folder wasn't important. Those are created and populated if/as needed.
I can't imagine why a forum post would say "add skip challenge requests to server config". That's, well, not possible to skip challenges. If you have the post please share it so we can correct that person.
In short, there was a lot to unpack in your first post. The mystery WebDAV I found on my own was as good a place as any to start.
If you become unsatisfied with ZeroSSL come on back. I'm sure we can work through it.
Thanks for following through. That sample code results in the challenge handled in the HTTP VirtualHost and to redirect all other requests to HTTPS. That code sample, or something like it, can be helpful with certbot --webroot authentication.
I am not sure what he meant by "skip challenge requests". @rg305 may be the most prolific volunteer and with 22,000+ posts they won't all be golden
