Help Centos 7 No CA Certificate renewal problem
My domain is: bdnetbreeze.blackdragonnetworks.com
My web server is (include version):login as: root
Authenticating with public key "rsa-key-20201105"
Last failed login: Mon Mar 8 14:56:12 CST 2021 from 222.91.97.134 on ssh:notty
There were 1141 failed login attempts since the last successful login.
Last login: Mon Mar 8 12:11:51 2021 from bzq-79-179-34-141.red.bezeqint.net
[root@bdnetbreeze ~]# certbot renew
Processing /etc/letsencrypt/renewal/bdnetbreeze.blackdragonnetworks.com.conf
http-01 challenge for bdnetbreeze.blackdragonnetworks.com
Challenge failed for domain bdnetbreeze.blackdragonnetworks.com
Attempting to renew cert (bdnetbreeze.blackdragonnetworks.com) from /etc/letsencrypt/renewal/bdnetbreeze.blackdragonnetworks.com.conf produced an unexpected error: Some challenges have failed.. Skipping.
/etc/letsencrypt/live/bdnetbreeze.blackdragonnetworks.com/fullchain.pem (failure)
The operating system my web server runs on is (include version):Centos 7
My hosting provider, if applicable, is: Vultr
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 1.9.0
Hi @phonegal2
if you use webroot and if that doesn't work, you use the wrong webroot.
Checking
https://bdnetbreeze.blackdragonnetworks.com/.well-known/acme-challenge/1234
there is an answer:
Not Found
The requested URL /.well-known/acme-challenge/1234 was not found on this server.
undefined Server at localhost:8082
Looks like a router port forwarding port 443 extern -> port 8082 intern.
So you have to use the webroot of that port 8082 nginx.
PS: Or is there an Apache as proxy?
