Having problems to set TXT records on DNS zone
I am having a problem for multiple days that my TXT DNS records are apparentely not reachable nor foundable, I may have misconfigured something.
Domain: adg.seg.br
Dig Result:
dig txt _acme-challenge.adg.seg.br
; <<>> DiG 9.18.12-0ubuntu0.22.04.3-Ubuntu <<>> txt _acme-challenge.adg.seg.br
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 65069
;; flags: qr rd; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; WARNING: recursion requested but not available
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1400
;; QUESTION SECTION:
;_acme-challenge.adg.seg.br.    IN      TXT
;; AUTHORITY SECTION:
adg.seg.br.             900     IN      SOA     a.auto.dns.br. hostmaster.registro.br. 2023291930 1800 900 604800 900
DNS Records:
Thanks for your time,
llricci
Hi @lucasricci, and welcome to the LE community forum :slight_smile:
It may lack obviousness...
But when you create an entry in domain: example.com
as: entry.example.com
it becomes: entry.example.com.example.com
So... if you need: entry.example.com
only create: entry
[in the zone example.com]
Your TXT entry would be found at:
dig TXT _acme-challenge.adg.seg.br.adg.seg.br
OR
You are not adding those entries in the authoritative DNS zone.
adg.seg.br nameserver = a.auto.dns.br
adg.seg.br nameserver = b.auto.dns.br
But from the looks of these responses:
dig A     adg.seg.br.adg.seg.br a.auto.dns.br
;; ANSWER SECTION:
a.auto.dns.br.          3209    IN      A       200.160.2.88
dig A www.adg.seg.br.adg.seg.br a.auto.dns.br
;; ANSWER SECTION:
a.auto.dns.br.          3201    IN      A       200.160.2.88
It seems that all your entries have suffered the extra domain appended to the domain problem.
Yeah, I am aware of that. I just added _acme-challengin to the record after noticing that. The addtion page is like that:
However, it did not work, or I may have misunderstood it. I don't know what I am supposed to add here, when I used cloudflare in another domain it work just fine.
@rg305 Apparently this domain registrar do the convertion automatically, I first typed _acme-challenge.adg.seg.br but after changed it to _acme-challenge but it did not work either. I guess it can be a problem in the DNS itself, it may take longer to the changes to make effect. I will monitor in the next minutes to see if it works.
I see a TXT record now:
dig +short TXT _acme-challenge.adg.seg.br  a.auto.dns.br.
"5HqdD6POjNnIVRmSipXPRxWxHQyX1Tf0vcmMKFFpwqo"
Yup, me too, using a +trace that is. It probably took some time to propogate (internally). Although I also see Cloudflare DNS is currently being used, is that correct?
Note that it's not very useful to censor out the A records for the IP address: anyone on the public internet could resolve those: that's the whole idea behind DNS. Well, as Cloudflare is being used now and a.auto.dns.br seems to be emptied out, I guess it can be worth hiding the origin server now..
Note that with Cloudflare as your DNS provider, the dns-01 challenge is easily automated with the certbot-dns-cloudlare plugin. So no manual tinkering required!
Yep it is correct, I am now using Cloudflare DNS. I found it easier. Thanks for the help
