Getting Connection reset by peer, i have been struggling for two days with no success
I have been using letsencrypt certificate for 3 months. but i can not renew, i reinstalled certbot and tried to get new certificate with no success. i don't see any error in nginx error log. and A and AAAA records are created and both port 443 and port 80 are open.
my nginx config looks like this:
listen 80;
listen [::]:80;
server_name estudent.kmu.edu.et;
root /home/user/workspace/myapp/public;
passenger_enabled on;
passenger_app_env production;
estudent.kmu.edu.et
sudo certbot --nginx -d estudent.kmu.edu.et
Enter email address (used for urgent renewal and security notices) (Enter 'c' to
cancel): estudent.system@gmail.com
agree in order to register with the ACME server at
https://acme-v02.api.letsencrypt.org/directory
(A)gree/(C)ancel: A
Would you be willing to share your email address with the Electronic Frontier
Foundation, a founding partner of the Let's Encrypt project and the non-profit
organization that develops Certbot? We'd like to send you email about our work
encrypting the web, EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: Y
http-01 challenge for estudent.kmu.edu.et
Failed authorization procedure. estudent.kmu.edu.et (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://estudent.kmu.edu.et/.well-known/acme-challenge/641Di3Co-c_fFVHgeTorJvfICt0vY0Ayg5TfyUk5QlU: Connection reset by peer
    Domain: estudent.kmu.edu.et
    Type: connection
    Detail: Fetching
  • Your account credentials have been saved in your Certbot
nginx/1.14.0 (Ubuntu)
Ubuntu 18.04.5 LTS (GNU/Linux 4.15.0-117-generic x86_64)
Ethio Telecom(Ethiopia)
Yes
No
certbot 0.31.0
Hi @yohannes
see your error: Your port 80 doesn't work. A working port 80 is required if you want to use http validation.
Is there a firewall?
What says
nginx -T
Hello @JuergenAuer Thank Your for quick response,
nginx -T results in
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
	worker_connections 768;
	# multi_accept on;
http {
	# Basic Settings
	sendfile on;
	tcp_nopush on;
	tcp_nodelay on;
	keepalive_timeout 65;
	types_hash_max_size 2048;
	# server_tokens off;
	server_names_hash_bucket_size 64;
	# SSL Settings
	ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
	ssl_prefer_server_ciphers on;
	# Logging Settings
	# Gzip Settings
	gzip on;
	# gzip_vary on;
	# gzip_proxied any;
	# gzip_comp_level 6;
	# gzip_buffers 16 8k;
	# gzip_http_version 1.1;
	# Virtual Host Configs
#mail {
#	# See sample authentication script at:
#	# http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#	# auth_http localhost/auth.php;
#	# pop3_capabilities "TOP" "USER";
#	# imap_capabilities "IMAP4rev1" "UIDPLUS";
#	server {
#		listen     localhost:110;
#		protocol   pop3;
#		proxy      on;
#	server {
#		listen     localhost:143;
#		protocol   imap;
#		proxy      on;
# configuration file /etc/nginx/modules-enabled/10-mod-http-ndk.conf:
load_module modules/ndk_http_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-auth-pam.conf:
load_module modules/ngx_http_auth_pam_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-cache-purge.conf:
load_module modules/ngx_http_cache_purge_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-dav-ext.conf:
load_module modules/ngx_http_dav_ext_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-echo.conf:
load_module modules/ngx_http_echo_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-fancyindex.conf:
load_module modules/ngx_http_fancyindex_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-headers-more-filter.conf:
load_module modules/ngx_http_headers_more_filter_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-lua.conf:
load_module modules/ngx_http_lua_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-passenger.conf:
load_module /usr/lib/nginx/modules/ngx_http_passenger_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-perl.conf:
load_module modules/ngx_http_perl_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-subs-filter.conf:
load_module modules/ngx_http_subs_filter_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-uploadprogress.conf:
load_module modules/ngx_http_uploadprogress_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-upstream-fair.conf:
load_module modules/ngx_http_upstream_fair_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-nchan.conf:
load_module modules/ngx_nchan_module.so;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/png                             png;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/svg+xml                         svg svgz;
    image/webp                            webp;
    application/font-woff                 woff;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.wap.wmlc              wmlc;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet          xlsx;
    application/vnd.openxmlformats-officedocument.presentationml.presentation  pptx;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
# configuration file /etc/nginx/conf.d/mod-http-passenger.conf:
### Begin automatically installed Phusion Passenger config snippet ###
passenger_root /usr/lib/ruby/vendor_ruby/phusion_passenger/locations.ini;
passenger_ruby /home/winner/.rbenv/shims/ruby;
### End automatically installed Phusion Passenger config snippet ###
# configuration file /etc/nginx/sites-enabled/estudent.conf:
  listen 80;
  listen [::]:80;
  server_name 10.1.5.4;
  root /home/winner/workspace/erp/public;
  location /cable {
    passenger_app_group_name estudent_websocket;
    passenger_force_max_concurrent_requests_per_process 0;
  # Allow uploads up to 15MB in size
  client_max_body_size 15M;
  location ~ ^/(assets|packs) {
    expires max;
   gzip_static on;
  listen 80;
  listen [::]:80;
  server_name estudent.kmu.edu.et 197.156.85.251;
  location /cable {
    expires max;
   gzip_static on;
Mhm. An ip address as server_name?
Works http internal, from that machine?
curl http://estudent.kmu.edu.et/
If yes, it's a firewall / routing problem.
Wireshark dump of curl -LIv estudent.kmu.edu.et:
39	11.240774406	192.168.178.26	197.156.85.251	TCP	74	41996 → 80 [SYN] Seq=0 Win=64240 Len=0 MSS=1460 SACK_PERM=1 TSval=2151445194 TSecr=0 WS=128
40	11.415093858	197.156.85.251	192.168.178.26	TCP	74	80 → 41996 [SYN, ACK] Seq=0 Ack=1 Win=65160 Len=0 MSS=1452 SACK_PERM=1 TSval=17299256 TSecr=2151445194 WS=12841	11.415140697	192.168.178.26	197.156.85.251	TCP	66	41996 → 80 [ACK] Seq=1 Ack=1 Win=64256 Len=0 TSval=2151445368 TSecr=17299256
42	11.415308068	192.168.178.26	197.156.85.251	HTTP	150	HEAD / HTTP/1.1
43	11.553449903	197.156.85.251	192.168.178.26	TCP	54	80 → 41996 [RST, NS, Reserved] Seq=1 Win=64256 Len=0
After the HTTP request by the client, your server immediately closes the connection with a reset. This is probably due to a misconfiguration of your nginx, or even more probably, that backend I've never heared about, Phusion Passenger.
If you're 200 % sure your nginx logs don't record any error, you should look at the Phusion Passenger logs.
@JuergenAuer yes it works internally with local ip and publicly through domain name. and i want to add ssl to the public domain only.
Then it's a firewall- or something else problem.
May be that Phusion Passenger requires some additional configurations to allow external access.
@Osiris, @JuergenAuer Thank you i will check the passenger logs and i will let you know. Thank You!
Hello @JuergenAuer, @Osiris
I tried to look at the Phusion Passenger loges and for some reason certbot tries to restart passenger. is that normal behavior? if not how could i prevent it from happening? these is the log i get.
What i did here:
  • restart nginx with 'sudo service nginx restart'
  • clear nginx error log(passenger also writes to nginx log file)
  • sudo certbot --nginx -d estudent.kmu.edu.et
and this is what i get from the log file.
2020/11/13 08:10:01 [info] 7116#7116: Using 32768KiB of shared memory for nchan in /etc/nginx/nginx.conf:63
2020/11/13 08:10:03 [notice] 7118#7118: signal process started
[ N 2020-11-13 08:10:03.8016 6822/T8 age/Cor/CoreMain.cpp:671 ]: Signal received. Gracefully shutting down... (send signal 2 more time(s) to force shutdown)
[ N 2020-11-13 08:10:03.8017 6822/T1 age/Cor/CoreMain.cpp:1246 ]: Received command to shutdown gracefully. Waiting until all clients have disconnected...
[ N 2020-11-13 08:10:03.8017 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 6954, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8018 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 6972, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8019 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 6990, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8020 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 7008, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8020 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 7026, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8021 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 7045, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8022 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 7063, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8022 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 7082, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8023 6822/Te Ser/Server.h:902 ]: [ServerThr.4] Freed 0 spare client objects
[ N 2020-11-13 08:10:03.8023 6822/Tc Ser/Server.h:902 ]: [ServerThr.3] Freed 0 spare client objects
[ N 2020-11-13 08:10:03.8023 6822/T8 Ser/Server.h:902 ]: [ServerThr.1] Freed 0 spare client objects
[ N 2020-11-13 08:10:03.8023 6822/Te Ser/Server.h:558 ]: [ServerThr.4] Shutdown finished
[ N 2020-11-13 08:10:03.8023 6822/Ta Ser/Server.h:902 ]: [ServerThr.2] Freed 0 spare client objects
[ N 2020-11-13 08:10:03.8024 6822/Tj Ser/Server.h:902 ]: [ServerThr.6] Freed 0 spare client objects
[ N 2020-11-13 08:10:03.8024 6822/Tc Ser/Server.h:558 ]: [ServerThr.3] Shutdown finished
[ N 2020-11-13 08:10:03.8024 6822/T8 Ser/Server.h:558 ]: [ServerThr.1] Shutdown finished
[ N 2020-11-13 08:10:03.8024 6822/Tj Ser/Server.h:558 ]: [ServerThr.6] Shutdown finished
[ N 2020-11-13 08:10:03.8024 6822/Ta Ser/Server.h:558 ]: [ServerThr.2] Shutdown finished
[ N 2020-11-13 08:10:03.8024 6822/Tl Ser/Server.h:902 ]: [ServerThr.7] Freed 0 spare client objects
[ N 2020-11-13 08:10:03.8024 6822/Tm Ser/Server.h:902 ]: [ServerThr.8] Freed 0 spare client objects
[ N 2020-11-13 08:10:03.8024 6822/Tl Ser/Server.h:558 ]: [ServerThr.7] Shutdown finished
[ N 2020-11-13 08:10:03.8023 6822/Tg Ser/Server.h:902 ]: [ServerThr.5] Freed 0 spare client objects
[ N 2020-11-13 08:10:03.8024 6822/Tm Ser/Server.h:558 ]: [ServerThr.8] Shutdown finished
[ N 2020-11-13 08:10:03.8024 6822/Tg Ser/Server.h:558 ]: [ServerThr.5] Shutdown finished
[ N 2020-11-13 08:10:03.8025 6822/To Ser/Server.h:902 ]: [ApiServer] Freed 0 spare client objects
[ N 2020-11-13 08:10:03.8025 6822/To Ser/Server.h:558 ]: [ApiServer] Shutdown finished
[ N 2020-11-13 08:10:03.8027 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 6954, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8027 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 6972, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8028 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 6990, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8029 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 7008, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8029 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 7026, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8030 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 7045, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8030 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 7063, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8031 6822/T1 age/Cor/CoreMain.cpp:1147 ]: Checking whether to disconnect long-running connections for process 7082, application /home/winner/workspace/erp (production)
[ N 2020-11-13 08:10:03.8480 7119/T1 age/Wat/WatchdogMain.cpp:1373 ]: Starting Passenger watchdog...
[ N 2020-11-13 08:10:03.9060 7125/T1 age/Cor/CoreMain.cpp:1340 ]: Starting Passenger core...
[ N 2020-11-13 08:10:03.9063 7125/T1 age/Cor/CoreMain.cpp:256 ]: Passenger core running in multi-application mode.
[ N 2020-11-13 08:10:04.0197 7125/T1 age/Cor/CoreMain.cpp:1015 ]: Passenger core online, PID 7125
[ N 2020-11-13 08:10:04.9645 6822/T1 age/Cor/CoreMain.cpp:1325 ]: Passenger core shutdown finished
[ N 2020-11-13 08:10:06.7262 7125/T5 age/Cor/SecurityUpdateChecker.h:519 ]: Security update check: no update found (next check in 24 hours)
2020/11/13 08:10:09 [notice] 7169#7169: signal process started
[ N 2020-11-13 08:10:09.3306 7125/T7 age/Cor/CoreMain.cpp:671 ]: Signal received. Gracefully shutting down... (send signal 2 more time(s) to force shutdown)
[ N 2020-11-13 08:10:09.3307 7125/T1 age/Cor/CoreMain.cpp:1246 ]: Received command to shutdown gracefully. Waiting until all clients have disconnected...
[ N 2020-11-13 08:10:09.3308 7125/Tf Ser/Server.h:902 ]: [ServerThr.4] Freed 0 spare client objects
[ N 2020-11-13 08:10:09.3308 7125/Th Ser/Server.h:902 ]: [ServerThr.5] Freed 0 spare client objects
[ N 2020-11-13 08:10:09.3308 7125/Tc Ser/Server.h:902 ]: [ServerThr.3] Freed 0 spare client objects
[ N 2020-11-13 08:10:09.3308 7125/Th Ser/Server.h:558 ]: [ServerThr.5] Shutdown finished
[ N 2020-11-13 08:10:09.3308 7125/Tf Ser/Server.h:558 ]: [ServerThr.4] Shutdown finished
[ N 2020-11-13 08:10:09.3308 7125/Tl Ser/Server.h:902 ]: [ServerThr.7] Freed 0 spare client objects
[ N 2020-11-13 08:10:09.3308 7125/Tc Ser/Server.h:558 ]: [ServerThr.3] Shutdown finished
[ N 2020-11-13 08:10:09.3308 7125/Tn Ser/Server.h:902 ]: [ServerThr.8] Freed 0 spare client objects
[ N 2020-11-13 08:10:09.3308 7125/Tj Ser/Server.h:902 ]: [ServerThr.6] Freed 0 spare client objects
[ N 2020-11-13 08:10:09.3308 7125/Tl Ser/Server.h:558 ]: [ServerThr.7] Shutdown finished
[ N 2020-11-13 08:10:09.3308 7125/Tn Ser/Server.h:558 ]: [ServerThr.8] Shutdown finished
[ N 2020-11-13 08:10:09.3308 7125/T7 Ser/Server.h:902 ]: [ServerThr.1] Freed 0 spare client objects
[ N 2020-11-13 08:10:09.3308 7125/Tj Ser/Server.h:558 ]: [ServerThr.6] Shutdown finished
[ N 2020-11-13 08:10:09.3309 7125/T7 Ser/Server.h:558 ]: [ServerThr.1] Shutdown finished
[ N 2020-11-13 08:10:09.3309 7125/Ta Ser/Server.h:902 ]: [ServerThr.2] Freed 0 spare client objects
[ N 2020-11-13 08:10:09.3310 7125/To Ser/Server.h:902 ]: [ApiServer] Freed 0 spare client objects
[ N 2020-11-13 08:10:09.3310 7125/Ta Ser/Server.h:558 ]: [ServerThr.2] Shutdown finished
[ N 2020-11-13 08:10:09.3310 7125/To Ser/Server.h:558 ]: [ApiServer] Shutdown finished
[ N 2020-11-13 08:10:09.3780 7173/T1 age/Wat/WatchdogMain.cpp:1373 ]: Starting Passenger watchdog...
[ N 2020-11-13 08:10:09.4032 7176/T1 age/Cor/CoreMain.cpp:1340 ]: Starting Passenger core...
[ N 2020-11-13 08:10:09.4034 7176/T1 age/Cor/CoreMain.cpp:256 ]: Passenger core running in multi-application mode.
[ N 2020-11-13 08:10:09.4428 7176/T1 age/Cor/CoreMain.cpp:1015 ]: Passenger core online, PID 7176
[ N 2020-11-13 08:10:10.0810 7125/T1 age/Cor/CoreMain.cpp:1325 ]: Passenger core shutdown finished
[ N 2020-11-13 08:10:12.2669 7176/T5 age/Cor/SecurityUpdateChecker.h:519 ]: Security update check: no update found (next check in 24 hours)
2020/11/13 08:10:16 [crit] 6851#6851: *2 connect() to unix:/tmp/passenger.9Yg8XQo/agents.s/core failed (2: No such file or directory) while connecting to upstream, client: 196.191.53.229, server: estudent.kmu.edu.et, request: "GET /estudent/ HTTP/1.1", upstream: "passenger:unix:/tmp/passenger.9Yg8XQo/agents.s/core:", host: "197.156.85.251", referrer: "http://197.156.85.251/estudent"
Seeing this log will be useful:
Also seeing the renewal config file may be useful.
Maybe:
/etc/letsencrypt/renewal/estudent.kmu.edu.et.conf
And also seeing if there are any hooks being called:
ls -Rl /etc/letsencrypt/renewal-hooks/
Hello @rg305
letsencrypt.log shows this error
2020-11-13 08:49:07,643:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/8568133943:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMTAyMTMzNjcxIiwgIm5vbmNlIjogIjAwMDRTQlkxbGQwVXczeFJzN29jOXR3aVZrSzFWSmJpdjVMbUJLVVQ5MmV5RjkwIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My84NTY4MTMzOTQzIn0",
"signature": "mfkteesdbySRVYDrBM91IXX_DSzAmIeIvvdPL3516DpgDUTkQQ9saVWdVLG87X9qzYZN44GtaPM0l1RQowL30zT2nHFdWskQzvp8aqlDpBQXd9QrLsfIwLmnSsqZVavjLxulCDHQGrrpstXvbT3GgWcGl9M0ZWllaF1FmO0vyIMyWEXCUaM4bO4K9l0rfd7lBFCfmfhE5wXj6mICMgVuCNOyPmOfvACpVYKvRCEYzoNcWujZ5Bglcmao-P1M0JPLaQu5ox87oxNaVUYtL4TVCFO5qC3TCZWPvqWdvcmChORwBTUtwXruQQ_bS0ASM83Kj7INuO0d-jhMI58dADj8Vw",
"payload": ""
2020-11-13 08:49:07,915:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/8568133943 HTTP/1.1" 200 992
2020-11-13 08:49:07,915:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Fri, 13 Nov 2020 05:49:07 GMT
Content-Length: 992
Boulder-Requester: 102133671
Link: https://acme-v02.api.letsencrypt.org/directory;rel="index"
Replay-Nonce: 0003FtlRZw-sOLkqevK4iI7Upfn-13S5FKSZXfFeTukRbKc
X-Frame-Options: DENY
"identifier": {
"type": "dns",
"value": "estudent.kmu.edu.et"
"status": "invalid",
"expires": "2020-11-20T05:49:02Z",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:connection",
"detail": "Fetching http://estudent.kmu.edu.et/.well-known/acme-challenge/jeJMmx_Cu_3WlEB73Z3Plu_hiTumPUG48Vr4DcY29ho: Connection reset by peer",
"status": 400
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/8568133943/QtGYmQ",
"token": "jeJMmx_Cu_3WlEB73Z3Plu_hiTumPUG48Vr4DcY29ho",
"validationRecord": [
"url": "http://estudent.kmu.edu.et/.well-known/acme-challenge/jeJMmx_Cu_3WlEB73Z3Plu_hiTumPUG48Vr4DcY29ho",
"hostname": "estudent.kmu.edu.et",
"port": "80",
"addressesResolved": [
"197.156.85.251"
"addressUsed": "197.156.85.251"
2020-11-13 08:49:07,915:DEBUG:acme.client:Storing nonce: 0003FtlRZw-sOLkqevK4iI7Upfn-13S5FKSZXfFeTukRbKc
2020-11-13 08:49:07,916:DEBUG:certbot.reporter:Reporting to user: The following errors were reported by the server:
Type: connection
Detail: Fetching http://estudent.kmu.edu.et/.well-known/acme-challenge/jeJMmx_Cu_3WlEB73Z3Plu_hiTumPUG48Vr4DcY29ho: Connection reset by peer
sudo cat /etc/letsencrypt/renewal/estudent.kmu.edu.et.conf
cat: /etc/letsencrypt/renewal/estudent.kmu.edu.et.conf: No such file or directory
i reinstalled certbot and i am not trying to renew!
sudo ls -Rl /etc/letsencrypt/renewal-hooks/
/etc/letsencrypt/renewal-hooks/:
total 12
drwxr-xr-x 2 root root 4096 Nov 12 20:57 deploy
drwxr-xr-x 2 root root 4096 Nov 12 20:57 post
drwxr-xr-x 2 root root 4096 Nov 12 20:57 pre
/etc/letsencrypt/renewal-hooks/deploy:
total 0
/etc/letsencrypt/renewal-hooks/post:
total 0
/etc/letsencrypt/renewal-hooks/pre:
total 0
So this would be the first cert for certbot?
since i couldn't renew the certs. i uninstalled and reinstalled certbot and i am trying to get a new cert. and the certs were expired!
Please show:
certbot certificates
And also try:
certbot certonly --webroot -w /home/winner/workspace/erp/public -d estudent.kmu.edu.et
Thank You for your quick response.
but i get similar error
No certs found.
and
$ sudo certbot certonly --webroot -w /home/winner/workspace/erp/public -d estudent.kmu.edu.et
Using the webroot path /home/winner/workspace/erp/public for all unmatched domains.
Failed authorization procedure. estudent.kmu.edu.et (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://estudent.kmu.edu.et/.well-known/acme-challenge/TEQgSWmq4YcipY9JF9pNRN2LNutR7c-kzd9yMEtcGnQ: Connection reset by peer
    Type: connection
    Detail: Fetching
I'm seeing the exact same thing:
curl http://estudent.kmu.edu.et/.well-known/acme-challenge/TEQgSWmq4YcipY9JF9pNRN2LNutR7c-kzd9yMEtcGnQ
curl -v http://estudent.kmu.edu.et/
*   Trying 197.156.85.251...
* TCP_NODELAY set
* Connected to estudent.kmu.edu.et (197.156.85.251) port 80 (#0)
> GET / HTTP/1.1
> Host: estudent.kmu.edu.et
> User-Agent: curl/7.58.0
> Accept: */*
* Recv failure: Connection reset by peer
* stopped the pause stream!
* Closing connection 0
There is something about your web config that isn't right.
@rg305 that must be it!
but it is ok on myside.
  • Trying 197.156.85.251:80...
  • TCP_NODELAY set
  • Connected to estudent.kmu.edu.et (197.156.85.251) port 80 (#0)
GET / HTTP/1.1
User-Agent: curl/7.68.0
Accept: /
  • Mark bundle as not supporting multiuse
    < HTTP/1.1 301 Moved Permanently
    < Content-Type: text/html
    < Content-Length: 103
    < Connection: keep-alive
    < Status: 301 Moved Permanently
    < Cache-Control: no-cache
    < X-Request-Id: b6cf88b1-ca25-49f3-9592-1bb2ddaa2173
    < Location: http://estudent.kmu.edu.et/auth/login
    < X-Runtime: 0.000950
    < Date: Fri, 13 Nov 2020 06:19:19 GMT
    < X-Powered-By: Phusion Passenger 6.0.6
    < Server: nginx/1.14.0 + Phusion Passenger 6.0.6
  • Connection #0 to host estudent.kmu.edu.et left intact
You are being redirected.
Is there a firewall or proxy between your server and the Internet?
@rg305 Yes there is firewall. but both port 80 and 443 are open. what could it be? i don't have access to the firewall
Firewall policy prohibiting
GeoLocation blocking
IPS rule
Inline proxy
Honeypot
Fail2BAN
I could go on.
There are many reasons why things can fail.
Before going to network/firewall teams for help, can you review the nginx logs for incoming http connections?
Do you see requests to /.well-known/acme-challenge/... in either log?
