Getting cert error trying to issue for adguard home for encrption
My domain is: tbluhp.online but adguard lives at adguard.tbluhp.online
I ran this command: export NAMECHEAP_API_KEY="redacted"
export NAMECHEAP_USERNAME="tbluhp"
export NAMECHEAP_SOURCEIP="136.47.213.206"
acme.sh --issue --dns dns_namecheap -d tbluhp.online --server letsencrypt
It produced this output: issued certs and I located them they are there I opened them copy and paste the contacts of the files . It was my only way since pasting the file path said invalid.
My web server is (include version): I am not using a web server but I use namecheap for domain and hosting.
The operating system my web server runs on is (include version): Mac 26
My hosting provider, if applicable, is: Namecheap
I can login to a root shell on my machine (yes or no, or I don't know): Yes its the only way i login
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Cpanel 126.0.27
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): v3.1.2
I'm preeeetty sure you don't want to share your NameCheap API key with like, ANYBODY! API keys are to be kept a secret.
I have removed the key just now, but it might have been indexed by search engines et c. You need to change the API key ASAP!
You've successfully issued several certs over the past few days:
What is your question?
my problem is the certs yes they work but I am getting this error * Certificate chain is invalid"
It also prevents me from using dns over https or dns over tis using the iOS/mac convigiration profiles.
Then you've misconfigured something. What? How? No idea, you've given us literally no information about what you've done--but as this isn't the support forum for Adguard Home, it might not matter if you had. I'd suggest you check there about how to properly configure your software.
Thabks I got it working now somewhat my site isbt accassavle at the moment. hmmm it was a few seconds ago.
