AdGuard Home Certificate chain is invalid
I am using Ubuntu 22 VPS hosted by Interserver.net
I ran the certbot to obtain a encryption certificate (pem) and everything went find. There were no errors doing it.
When I go to enter the information into AdGuard Home the private key entry has no location.
The certificate however shows the following:
In order to use encryption, you need to provide a valid SSL certificates chain for your domain. You can get a free certificate on letsencrypt.org or you can buy it from one of the trusted Certificate Authorities.
Status:
Any ideas how to get rid of that error?
Hello @jkshowers, welcome to the Let's Encrypt community. :slightly_smiling_face:
Have a look at Long (default) and Short (alternate) Certificate Chains Explained
Also:
Thank you for assisting us in helping YOU!
Domain: arandomdomain.net
These are the commands I used:
sudo snap install --classic certbot
sudo ln -s /snap/bin/certbot /usr/bin/certbot
sudo certbot certonly --standalone
Output was no errors and a Cetificate (SSL) and private key were created in the following directory
/etc/letsencrypt/live/arandomdomain.net/fullchain.pem
Error given in adguard:
Status:
/etc/letsencrypt/live/arandomdomain.net/privkey.pem
Good to go message:
Status:
  • This is a valid ECDSA private key
I am not sure the webserver I am using to be honest. But the server giving me the error is AdGuard Home.
Ubuntu 22 is the OS
Interserver.net is the hosting provider
I do have root access in SSH
No control panel is installed outside of AdGuard Home
Certbot should be the latest version as it was installed yesterday
I find no IP Addresses for the domain name.
>nmap -4 -Pn -p80,443 arandomdomain.net
Starting Nmap 7.93 ( https://nmap.org ) at 2023-05-15 19:08 UTC
Failed to resolve "arandomdomain.net".
WARNING: No targets were specified, so 0 hosts scanned.
Nmap done: 0 IP addresses (0 hosts up) scanned in 0.44 seconds
>nmap -6 -Pn -p80,443 arandomdomain.net
Nmap done: 0 IP addresses (0 hosts up) scanned in 0.29 seconds
And using the online tool Let's Debug yields these results https://letsdebug.net/arandomdomain.net/1481727
and https://letsdebug.net/arandomdomain.net/1481728
Yes.
#1 Use the "long chain"
#2 Use another free CA
#3 Verify the correct cert files in use:
Which files did you provide to Adguard?
#4 Upgrade Adguard to latest version
#5 Windows Updates
The domain name servers are not reporting information about the domain
$ nslookup -q=ns arandomdomain.net
Server:         127.0.0.53
Address:        127.0.0.53#53
** server can't find arandomdomain.net: SERVFAIL
$ nslookup -q=ns arandomdomain.net DNS2031A.TROUBLE-FREE.NET.
Server:         DNS2031A.TROUBLE-FREE.NET.
Address:        64.20.52.123#53
** server can't find arandomdomain.net: REFUSED
Sounds... a bit made up.
Could you perhaps explain a little bit more why you're trying to get a certificate installed in your "AdGuard Home"?
Are you following instructions such as these?
Did you paste the cert.pem file or the fullchain.pem file (should be the latter)
And, what do you mean there was no spot for the private key. Does your screen not look like here in Configure AdGuard Home
Thank you all so much for reaching out and the help. The DNS for the domain hand;t quite set up and needed a tweak. I figured that out when one of you mentioned and showed the domain errors. I reformated the server. Reran the certbot and then installed AdGuard Home and did it again and all went through.'
Thank you Thank you Thank
J K
