Get https://acme-v01.api.letsencrypt.org/directory: ...: read: connection refused
Hello,
My domain is: https:chilango.me
I ran this command: docker-compose up
traefik_1 | time=“2017-08-25T15:41:18+02:00” level=error msg="Error creating TLS config: get directory at ‘https://acme-v01.api.letsencrypt.org/directory’: failed to get json “https://acme-v01.api.letsencrypt.org/directory”: Get https://acme-v01.api.letsencrypt.org/directory: dial tcp: lookup acme-v01.api.letsencrypt.org on 127.0.0.11:53: read udp 127.0.0.1:54642->127.0.0.11:53: read: connection refused"
traefik_1 | time=“2017-08-25T15:41:18+02:00” level=fatal msg=“Error preparing server: get directory at ‘https://acme-v01.api.letsencrypt.org/directory’: failed to get json “https://acme-v01.api.letsencrypt.org/directory”: Get https://acme-v01.api.letsencrypt.org/directory: dial tcp: lookup acme-v01.api.letsencrypt.org on 127.0.0.11:53: read udp 127.0.0.1:54642->127.0.0.11:53: read: connection refused”
4.4.0-83-generic (Linux)
My hosting provider, if applicable, is: Hertz
my toeml:
# https://docs.traefik.io/toml/
# Accepted values, in order of severity: "DEBUG", "INFO", "WARN", "ERROR", "FATAL", "PANIC"
# debug = true
# logLevel = "DEBUG"
defaultEntryPoints = ["http", "https"]
[web]
address = ":8080"
  # authendication traefik admin interface
  # https://docs.traefik.io/toml/#api-backend
  # htpasswd -nb username password
  [web.auth.basic]
  users = ["xx ;-)"]
[docker]
domain = "chilango.me"
watch = true
[entryPoints]
  [entryPoints.http]
  address = ":80"
    [entryPoints.http.redirect]
    entryPoint = "https"
  [entryPoints.https]
  address = ":443"
    [entryPoints.https.tls]
# https://docs.traefik.io/toml/#acme-lets-encrypt-configuration
[acme]
email = "xxxx ;-)"
storage = "acme/acme.json"
OnHostRule = true
acmeLogging = true
Hi @Schmaddin,
I'm not familiar with Traefik and my docker-fu is quite weak but this looks to me like the container is trying to perform a DNS lookup by talking to a stub resolver at 127.0.0.11 on port 53 but the connection is refused. Since the DNS lookup for the Let's Encrypt ACME server fails nothing will work.
I'm not sure what to suggest in terms of troubleshooting/debugging. Perhaps if you open an issue with the Traefik developers they could make more concrete suggestions?
Hope that helps!
