First time using Certbot - Certificate is not recognized
My domain is: maptile2.org
I followed the instructions at this URL
It properly installed the certificate.
sudo certbot --apache
I enabled it for
"1: maptile2.org"
And then I did an "1. Attempt to reinstall this existing certificate"
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/000-default-le-s sl.conf
Apache 2.4.38
Debian 10 buster
webserver hosted on kimsufi (no support)
no
certbot 0.31.0
Do you have port 443 open on your server's firewall? I can't access https://maptile2.org.
Where do you see the "Certificate is not recognized" error?
I am a novice linux user.
It appears that I'm not running a firewall.
systemctl --type=service
I'm using the default Debian 10 install - with only a couple of packages installed (notably postgresql).
I'm trying to load the website in my browser with https and it fails there and points me to this URL:
Can you take a screenshot of the error screen you get in your browser? The specific error message would be helpful.
I'd like to identify whether the problem is related to port 443 being inaccessible, or whether you're seeing something else, like a self-signed certificate.
From searching around other threads, I think PR_END_OF_FILE_ERROR is almost certainly related to port 443 being closed.
There's a couple of places you can look:
  1. Check whether any of your OVH IP addresses have their firewall enabled (see Configuring the Network Firewall | OVH Guides). If they do, you need to add a rule to permit port 443.
  2. You can check inside Debian to see whether anything has applied a firewall rule. You can use this command to get a full list of the rules that your server has applied at the moment:
    sudo iptables-save
Says the port is filtered.
Ah ha. I checked page two of the services (didn't know there was a second page). And I'm running ufw.service - "Uncomplicated firewall"
OK, so you can do:
sudo ufw allow https
Yes. Ok so that worked! Now it's self-signed so it looks like people are going to see error messages, which is bad.
Thanks!
Maybe I need to buy a certificate - which is annoying.
I don't see that - https://maptile2.org/ looks good to me.
Firefox made me do it to view the website. Chrome works fine. Hmm... I'll try to delete the exception and see if it still works.
Problem is with www.maptile2.org (maptile2.org is the only domain in the certificate). Ok this is fine.
You can replace your certificate with one that has both names by running:
sudo certbot --apache -d maptile2.org -d www.maptile2.org --cert-name maptile2.org --force-renewal
Awesome. I really appreciate your help! And this will really help my users. It's a volunteer run project mapping US census data and providing a free API.
