First renewal fails
My domain is: managedstorage.douganconsulting.com
I ran this command: .\ACMESharp.ps1
Alias :
Label :
Memo :
BaseService : LetsEncrypt
BaseUri : https://acme-v01.api.letsencrypt.org/
Signer :
PkiTool :
GetInitialDirectory : True
UseRelativeInitialDirectory : True
ServerDirectory : {[init, /directory], [directory, /directory], [new-reg, /acme/new-reg], [recover-reg, /recover-reg]…}
Proxy :
ProviderProfiles :
InstallerProfiles :
Registrations : {56f1006c-d5de-4d14-ab27-56af66c7d82d}
Identifiers : {00c64ccc-4d2d-4f50-9a50-f958e8384b98}
Certificates : {ff6a7ce1-ee2d-4afc-b549-add960bd717e, 97f4a8a0-b7eb-4062-add1-38b7dfb5fd9a}
IssuerCertificates : {[0A0141420000015385736A0B85ECA708, ACMESharp.Vault.Model.IssuerCertificateInfo]}
New-AcmeIdentifier : An item with the same key has already been added.
At C:\Users\Administrator.DCG\Documents\ACMESharp.ps1:37 char:5
  • New-AcmeIdentifier -Dns $domain -Alias $alias
    • CategoryInfo : NotSpecified: (:slight_smile: [New-ACMEIdentifier], ArgumentException
    • FullyQualifiedErrorId : System.ArgumentException,ACMESharp.POSH.NewIdentifier
Complete-ACMEChallenge : no challenge found matching requested type
Parameter name: challengeType
At C:\Users\Administrator.DCG\Documents\ACMESharp.ps1:40 char:5
  • Complete-ACMEChallenge $alias -ChallengeType http-01 -Handler iis ...
    • CategoryInfo : NotSpecified: (:slight_smile: [Complete-ACMEChallenge], ArgumentOutOfRangeException
    • FullyQualifiedErrorId : System.ArgumentOutOfRangeException,ACMESharp.POSH.CompleteChallenge
Submit-ACMEChallenge : no challenge found matching requested type
At C:\Users\Administrator.DCG\Documents\ACMESharp.ps1:43 char:5
  • Submit-ACMEChallenge $alias -ChallengeType http-01
    • CategoryInfo : NotSpecified: (:slight_smile: [Submit-ACMEChallenge], ArgumentException
    • FullyQualifiedErrorId : System.ArgumentException,ACMESharp.POSH.SubmitChallenge
Update-ACMEIdentifier : no challenge found matching requested type
Parameter name: type
At C:\Users\Administrator.DCG\Documents\ACMESharp.ps1:46 char:5
  • Update-ACMEIdentifier $alias -ChallengeType http-01
    • CategoryInfo : NotSpecified: (:slight_smile: [Update-ACMEIdentifier], ArgumentOutOfRangeException
    • FullyQualifiedErrorId : System.ArgumentOutOfRangeException,ACMESharp.POSH.UpdateIdentifier
At C:\Users\Administrator.DCG\Documents\ACMESharp.ps1:47 char:5
Alias : managedstorage2018-10-28–10-07
Label :
Memo :
IdentifierRef : 00c64ccc-4d2d-4f50-9a50-f958e8384b98
IdentifierDns : managedstorage.douganconsulting.com
AlternativeIdentifierDns :
KeyPemFile :
CsrPemFile :
GenerateDetailsFile : 123ff9fe-c34c-49e0-b50c-80cf46c29cf7-gen.json
CertificateRequest :
CrtPemFile :
CrtDerFile :
IssuerSerialNumber :
SerialNumber :
Thumbprint :
Signature :
SignatureAlgorithm :
RevokedAt :
Submit-ACMECertificate : Error creating new cert :: authorizations for these names not found or expired: managedstorage.douganconsulting.com
At C:\Users\Administrator.DCG\Documents\ACMESharp.ps1:54 char:1
  • Submit-ACMECertificate $certname
  •   + CategoryInfo          : PermissionDenied: (ACMESharp.Vault.Model.CertificateInfo:CertificateInfo) [Submit-ACMECertificate], AcmeWebException
      + FullyQualifiedErrorId : urn:acme:error:unauthorized (403),ACMESharp.POSH.SubmitCertificate
update-AcmeCertificate : Certificate has not been submitted yet; cannot update status
At C:\Users\Administrator.DCG\Documents\ACMESharp.ps1:57 char:1
  • update-AcmeCertificate $certname
  •   + CategoryInfo          : NotSpecified: (:) [Update-ACMECertificate], Exception
      + FullyQualifiedErrorId : System.Exception,ACMESharp.POSH.UpdateCertificate
Press Enter to continue…:
Get-ACMECertificate : Cannot export PKCS12; private hasn’t been imported or generated
At C:\Users\Administrator.DCG\Documents\ACMESharp.ps1:62 char:1
  • Get-ACMECertificate $certname -ExportPkcs12 $pfxfile
  •   + CategoryInfo          : NotSpecified: (:) [Get-ACMECertificate], InvalidOperationException
      + FullyQualifiedErrorId : System.InvalidOperationException,ACMESharp.POSH.GetCertificate
My web server is (include version): IIS version 10
The operating system my web server runs on is (include version): Server 2016
I created the cert and installed it a couple of months ago. I got an email from your bot that it is coming due for renewal, so I tried to run the ACME Sharp script with the results above.
Thanks for any assistance you can provide.
Des
Can you show the contents of file: ACMESharp.ps1
[I'm interested in seeing how/where those variables are defined.]
Thanks for replying.
I based it on this post on Rick Strahl's site.
The script is as follows:
#install-Module -Name ACMESharp
import-module ACMESharp
$email = "mailto:des@douganconsulting.com"
$domain = "managedstorage.douganconsulting.com"
$alias = "managedstorage"
$iissitename = "managedstorage.douganconsulting.com"
$certname = "managedstorage$(get-date -format yyyy-MM-dd--HH-mm)"
$pfxfile = "c:\Admin\Certs$certname.pfx"
$initializevault = $FALSE
$createregistration = $FALSE
$createalias = $TRUE
Change to the Vault folder
cd C:\ProgramData\ACMESharp\sysVault
First time on the machine - intiialize vault
if($initializevault)
Initialize-ACMEVault
Get-ACMEVault
if($createregistration)
# Set up new 'account' tied to an email address
New-AcmeRegistration -Contacts "$email" -AcceptTos
if($createalias)
# Associate a new site
# Prove the site exists and is accessible
Complete-ACMEChallenge $alias -ChallengeType http-01 -Handler iis -HandlerParameters @{WebSiteRef="$iissitename"}
# Validate site
# check until valid or invalid - pending
Generate a certificate
New-ACMECertificate ${alias} -Generate -Alias $certname
#Submit the certificate
Hit until values are filled in
pause
Export Certificate to PFX file
Thanks,
Des
I think the $alias may need to be an FQDN.
Shouldn't that be:
$certname
Thanks for your replies. To answer the second one - the script does have $certname - it was lost when copy/pasting.
I tried changing $alias as you suggested, and still get an issue:
PS C:\Users\Administrator.DCG\Documents> .\ACMESharp.ps1
Alias :
Label :
Memo :
Signer :
PkiTool :
Proxy :
ProviderProfiles :
InstallerProfiles :
Certificates : {ff6a7ce1-ee2d-4afc-b549-add960bd717e, 97f4a8a0-b7eb-4062-add1-38b7dfb5fd9a, 123ff9fe-c34c-49e0-b50c-80cf46c29cf7,
aa7fd889-b28a-4c2f-b5b4-0ee6320b0888}
IdentifierPart : ACMESharp.Messages.IdentifierPart
IdentifierType : dns
Identifier : managedstorage.douganconsulting.com
Uri : https://acme-v01.api.letsencrypt.org/acme/authz/Q9E5MRkwHpuXiqsd5Vizu_NmliAf44ObD87u1DuBsD4
Status : pending
Expires : 2018-11-19 1:44:33 AM
Challenges : {, , , }
Combinations : {0, 1, 2, 3}
Complete-ACMEChallenge : unresolved site for given site reference
    • CategoryInfo : NotSpecified: (:slight_smile: [Complete-ACMEChallenge], InvalidOperationException
    • FullyQualifiedErrorId : System.InvalidOperationException,ACMESharp.POSH.CompleteChallenge
Submit-ACMEChallenge : challenge has not been decoded
    • CategoryInfo : NotSpecified: (:slight_smile: [Submit-ACMEChallenge], InvalidOperationException
    • FullyQualifiedErrorId : System.InvalidOperationException,ACMESharp.POSH.SubmitChallenge
Status : pending
Status : pending
Alias : managedstorage2018-11-11–17-44
Label :
Memo :
IdentifierRef : c09c996b-a62a-4e9f-9641-97d90df18cf8
KeyPemFile :
CsrPemFile :
GenerateDetailsFile : abdb188f-0733-45f4-a8ce-0d58c053ac3c-gen.json
CrtPemFile :
CrtDerFile :
SerialNumber :
Thumbprint :
Signature :
RevokedAt :
Any feedback is appreciated - it expires in a few days, and I can’t see why it is not working.
Des
What is the FQDN used?
And you may want to modify the post title to include "ACMESharp"
Thanks,
Des
Using PS do (and show output of):
set-location cert:
cd .\\LocalMachine\My
gci | fl Thumbprint,Name,FriendlyName,Subject
PS C:\ProgramData\ACMESharp\sysVault> certutil -dump
CertUtil: -dump command completed successfully.
It doesn’t return anything.
Many thanks,
Des
set-location cert:
Rudy,
PS Cert:\LocalMachine\My> gci | fl Thumbprint,Name,FriendlyName,Subject
Thumbprint : 241D5CDDB6780F75071CEB710DAA5ED67946B80C
FriendlyName : CN=managedstorage.douganconsulting.com
Thanks,
Des
Try changing this to $FALSE and rerun.
Otherwise, have you manually added, or deleted, any certs?
Is the current cert still bound to the site in IIS?
[Again, this may dray attention from those who may know more on the subject:]
If you can't change the title maybe opening a new post with a more descriptive title would be best.
Cert is still active - I created it originally using ACMESharp.
The change had no effect:
Alias :
Label :
Memo :
Signer :
PkiTool :
Proxy :
ProviderProfiles :
InstallerProfiles :
Identifiers : {00c64ccc-4d2d-4f50-9a50-f958e8384b98, c09c996b-a62a-4e9f-9641-97d90df18cf8}
                          aa7fd889-b28a-4c2f-b5b4-0ee6320b0888...}
Alias : managedstorage2018-11-12–11-04
Label :
Memo :
KeyPemFile :
CsrPemFile :
GenerateDetailsFile : 37eab4c2-dc00-4f37-bfcc-ec3f6280bd55-gen.json
CrtPemFile :
CrtDerFile :
SerialNumber :
Thumbprint :
Signature :
RevokedAt :
des
I’m sorry I can’t see why this is failing…
I don’t use ACMEsharp :frowning:
Let me ping some others into this post:
ping @Osiris
ping @JuergenAuer
ping @mnordhoff
