"Firewall problem"?
Hello, my certs are about to expire. I've had them for years, but I'm getting a "firewall problem" error now. I've stopped iptables and fail2ban, double checked my DNS entries and basically am at a stuck point. I have two subdomains in use "ampache.thechatpit.org" and "nextcloud.thechatpit.org" but am not looking for a wildcard cert.
Please let me know if you need anything else.
My domain is: thechatpit.org
I ran this command: sudo certbot renew
It produced this output: Timeout during connect (likely firewall problem)
My web server is (include version): Server version: Apache/2.4.47 (Unix)
The operating system my web server runs on is (include version): Linux thechatpit.org 5.12.4-arch1-2 #1 SMP PREEMPT Sat, 15 May 2021 20:58:02 +0000 x86_64 GNU/Linux
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.15.0
It means just what it says; your web sites aren't accessible and need to be in order for Let's Encrypt to validate them. I can't get to them either. Some firewall or the like is blocking them, or the server isn't running.
Yes, I just found the problem... port forwarding in the router. My bad, but thanks
