Hello,
I’ve spent a few hours reading this forum and have been unable to resolve this issue. Port 80 is open on both the server and the router. I suspect I have some kind of configuration on apache setup to force HTTPS that may be interfering with certbot. I just can’t figure out how to fix it. Any help you can provide is appreciated.
System:
firewall-cmd --zone=public --list-all
public (active)
target: default
icmp-block-inversion: no
interfaces: eth0
sources:
services: dhcpv6-client http https ssh
ports:
protocols:
masquerade: no
forward-ports:
source-ports:
icmp-blocks:
rich rules:
My domain is: kristinandmatthew.com
Challenge failed for domain www.kristinandmatthew.com
http-01 challenge for www.kristinandmatthew.com
Attempting to renew cert (www.kristinandmatthew.com) from /etc/letsencrypt/renewal/www.kristinandmatthew.com.conf produced an unexpected error: Some challenges have failed… Skipping.
/etc/letsencrypt/live/www.kristinandmatthew.com/fullchain.pem (failure)
Domain: www.kristinandmatthew.com
Type: connection
Detail: Fetching
http://www.kristinandmatthew.com/.well-known/acme-challenge/wVIEGDTpjOhuarKFz3NT9-Fjx5EqX9T8uezAJ17O0Qg:
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
that you are serving files from the webroot path you provided. -
Your account credentials have been saved in your Certbot
My web server is (include version): Server version: Apache/2.4.6 (CentOS)
The operating system my web server runs on is (include version): CentOS 7
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 1.3.0
