My domain is: https://mobilise.alzheimersresearchuk.org/
I ran this command: certbot renew -v
Processing /etc/letsencrypt/renewal/mobilise.alzheimersresearchuk.org-0001.conf
Certificate is due for renewal, auto-renewing...
Renewing an existing certificate for mobilise.alzheimersresearchuk.org
http-01 challenge for mobilise.alzheimersresearchuk.org
Challenge failed for domain mobilise.alzheimersresearchuk.org
Domain: mobilise.alzheimersresearchuk.org
Type: connection
Detail: 185.61.132.68: Fetching http://mobilise.alzheimersresearchuk.org/.well-known/acme-challenge/SdGVNcXwOwn7PTSTdn5SzYsUJwH81Q0cbBx9zHVr71Y: Timeout during connect (likely firewall problem)
Failed to renew certificate mobilise.alzheimersresearchuk.org-0001 with error: Some challenges have failed.
/etc/letsencrypt/live/mobilise.alzheimersresearchuk.org-0001/fullchain.pem (failure)
My web server is (include version): nginx version: nginx/1.23.3
The operating system my web server runs on is (include version): Ubuntu 22.04/ Alpine Linux v3.17 nginx image
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.32.0 (on Alpine)
There is no record of any request incoming from the Certbot servers to 185.61.132.68
I tested port 80 it seems to be working
.well-known/acme-challenge/index.html this seems to be opening via a curl request on http
I need help in debuggin this. Is there a DNS problem or firewall problem. Why isn't it reaching the webserver?
