Failed to connect to acme-v02.api.letsencrypt.org port 443 after 130393 ms: Connection timed out
I'm trying to get a cerificate for the domain delirium.freemyip.com
The VPS I'm using, times out when connecting to https://acme-v02.api.letsencrypt.org/directory
Command certbot certonly --standalone --preferred-challenges http -d delirium.freemyip.com returns error:
An unexpected error occurred:
ValueError: Requesting acme-v02.api.letsencrypt.org/directory: Network is unreachable
My domain is: delirium.freemyip.com
I ran this command: curl -I https://acme-v02.api.letsencrypt.org/directory
It produced this output: Failed to connect to acme-v02.api.letsencrypt.org port 443 after 130393 ms: Connection timed out
My web server is (include version): 3x-ui
The operating system my web server runs on is (include version): Ubuntu 22.04.4 LTS
My hosting provider, if applicable, is: Not applicable (VPS)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
Welcome to the Let's Encrypt Community! :slightly_smiling_face:
Do you have outbound access enabled for port 443?
Hi! Yes, I have. Due to some problems I did it for several domens yesterday and it worked fine. I suspect that my ip might have been blocked because of this
ps sorry, forgot to mention it in topic
I could be wrong, but I don't think "network is unreachable" is the error you receive if your IP address has been blocked.
Maybe. That was my guess
A similar situation:
There was firewall problem. I tried to shutdown it and it didn't help
The problem was in my local dns cache. After cleaning i was able to get the certificate
