Failed authorization procedure: urn:acme:error:connection
My domain is: dataone.sensor.nevada.edu
I ran this command: sudo certbot --apache certonly
Failed authorization procedure. dataone.sensor.nevada.edu (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: CAA record for dataone.sensor.nevada.edu prevents issuance
    Domain: dataone.sensor.nevada.edu
    Type: connection
    Detail: CAA record for dataone.sensor.nevada.edu prevents issuance
My web server is (include version): apache 2.4.7
The operating system my web server runs on is (include version): Ubuntu 14.04
Is this a problem with the DNS server (which I don’t control)? Or am I messing something up? It was working fine for more than a year, up until a couple months ago and now I can’t seem to get any new certificates.
It turns out that nevada.edu has a CAA record only allowing issuance by DigiCert. If you have control over the DNS zone for dataone.sensor.nevada.edu, you can add your own CAA record allowing Let’s Encrypt to issue certificates for this domain. This record will take precedence over the nevada.edu record shown below as CAA records are evaluated on FQDNs from left to right, stopping at first result.
# dig nevada.edu CAA
; <<>> DiG 9.8.2rc1-RedHat-9.8.2-0.62.rc1.el6_9.4 <<>> nevada.edu CAA
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 24039
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;nevada.edu.                    IN      CAA
;; ANSWER SECTION:
nevada.edu.             3660    IN      CAA     0 iodef "mailto:hostmaster@nevada.edu"
nevada.edu.             3660    IN      CAA     0 issue "digicert.com"
;; Query time: 101 msec
;; SERVER: 172.18.10.20#53(172.18.10.20)
;; WHEN: Mon Aug 14 17:00:59 2017
;; MSG SIZE  rcvd: 106
Hello @unr-sensor,
The "problem" is here:
nevada.edu has a CAA record and only allows certificates issued by digicert:
$ dig nevada.edu caa +short
so Let's Encrypt can't issue a certificate for your domain. If you control the DNS you should be able to create a CAA record for dataone.sensor.nevada.edu where Let's Encrypt is authorized to issue a cert for this domain.
Cheers,
sahsanu
Thank you for the replies.
The issue is that acquiring the certificates from Let’s Encrypt for this domain used to work for more than a year. Is this extra CAA check a recent development by Let’s Encrypt?
No, it's not recent. I'd guess that nevada.edu added (or changed) the DNS records recently.
Ah ha. Thank you for that.
I’m currently communicating with the DNS admins to add a CAA record for my subdomain. Hopefully I’ll hear back soon.
Thank you all for the replies!
