Failed authorization procedure. iyouthconnect.com (http-01): urn:acme:error:dns :: DNS problem: SERVFAIL looking up A for iyouthconnect.com
Pls help me :frowning: i cant SSL my Website :frowning:
always DNS problem but my setting DNS looking good :frowning:
In My putty =
myserver:~# certbot --apache -d iyouthconnect.com
http-01 challenge for iyouthconnect.com
Waiting for verification…
I try Again :frowning:
myserver:~# certbot -d iyouthconnect.com -d www.iyouthconnect.com
http-01 challenge for www.iyouthconnect.com
Failed authorization procedure. www.iyouthconnect.com (http-01): urn:acme:error:dns :: DNS problem: SERVFAIL looking up A for www.iyouthconnect.com, iyouthconnect.com (http-01): urn:acme:error:dns :: DNS problem: SERVFAIL looking up A for iyouthconnect.com
Still Same error :frowning:
My Setting domain & VPS
The domain has a DS record, indicating it uses DNSSEC, but the DNS provider (DigitalOcean) doesn’t support DNSSEC. Validating resolvers will not be able to resolve it.
iyouthconnect.com.      86391   IN      DS      63931 8 2 3B6671831D781EE1CB0C086967EAA099D5617747C2BBBEA21AC43BBE 78A83D6D
You need to remove the DS record at your domain registrar before it will work.
If you want to use DNSSEC, you’ll have to switch DNS providers. Cloudflare would work. (You’d still have to change the DS record, though.)
I try it
thanks for your answer sir :slight_smile:
