Facing Challenges when renewing the SSL - Running Node application and Docker
My domain is: https://swpdev.macbiz.co
I ran this command: sudo certbot certonly --force-renew
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel):
My web server is (include version): Ubuntu 18.04
The operating system my web server runs on is (include version): Node server
My hosting provider, if applicable, is: AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
Do you already have a certificate previously issued by certbot?
If so, please read the certbot documentation: https://certbot.eff.org/docs/using.html#renewing-certificates
i don’t have nginx or apache web server running , its a simple nodejs application running on docker.
its asking me these two options
how do i move forward from here.
@kerlosense Your title specifically says “renewing the SSL”. This implies you already issued a certificate previously, which is nearly expired or has expired already and you want to renew this certificate, so it won’t expire (until the next expiry date).
Did you by any chance misunderstood the meaning of “renewing”? And do you want to get a brand new certificate issued for the first time? If yes, please say so, so we can help you with that in stead of renewing.
If you indeed already have a certificate which has expired or is near the expiry date and you’ve previously issued that certificate with certbot, I must refer to my previous post and urge you to read the certbot documentation.
Yes, i am trying to reinstall the SSL certificate and i have already followed the documentation but having problems which i couldn’t understand.
here is the screenshot of what i get
Where in the documentation showed it that command to renew? :pleading_face: I don't see it. Please forget your current command and read the documentation above again. It specifically links to the "How to renew" section and the command is even way simpler than the one you're using now.
Here is what i am following now:
and here is the output i get after issuing this command.
OK, good, sort of. You’ve issued your certificate previously with the --manual option it seems. Without the proper scripts called with --manual-auth-hook (and --manual-cleanup-hook), it is impossible to automatically renew your certificate like this.
If you cannot automate the adding and removing of the challenge tokens, you cannot automatically renew your certificate. This is not something Let’s Encrypt advices: Let’s Encrypt is all about automation.
Do you remember how you previously managed to do the challenges required for validation of your hostname?
Is there any way to reinstall a new certificate easily with auto renewal?
