I’m managing 100+ site network. At first I was putting several domains on 1 certificate, but then later that’s a problem is one goes away. So l’ve been using a single cert per domain, but when I go to renew this one I’m getting this error. Any thoughts on fixing this?
sudo certbot --apache -d surgicalcenterofsandiego.com
tls-sni-01 challenge for surgicalcenterofsandiego.com
Failed authorization procedure. surgicalcenterofsandiego.com (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested 827ef8746ad1b145cd9d000cc32bb38a.e90fc0bdd632fd98c1556340feed8c45.acme.invalid from 207.223.115.39:443. Received 2 certificate(s), first certificate had names "aksurgery.com, alaskaspinecenter.com, alliancelakemary.com, amsurgsurgerycenter.com, antelopevalleysurgerycenter.com, apogeesurgery.com, arcadiasurgerycenter.com, barrancasurgerycenter.com, bellevillesurgical.com"
Domain: surgicalcenterofsandiego.com
Detail: Incorrect validation certificate for tls-sni-01 challenge.
Requested
I would also like to move away from TLS-SNI-01 can I specify when using the apache plugin?
Thanks,
Dave
