Certificate renew problem
My domain is: www.vasarhelyanno.hu, vasarhelyanno.hu, api.vasarhelyanno.hu
I ran this command: certbot --apache certonly
1: vasarhelyanno.hu
2: api.vasarhelyanno.hu
3: static.vasarhelyanno.hu
4: www.static.vasarhelyanno.hu
5: www.vasarhelyanno.hu
blank to select all options shown (Enter ‘c’ to cancel): 2
tls-sni-01 challenge for api.vasarhelyanno.hu
Waiting for verification…
Failed authorization procedure. api.vasarhelyanno.hu (tls-sni-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested e4b04d2f57e715b1fd59000622a01da4.8b93d53a6186b5cc132154c49ab4ca82.acme.invalid from [2a00:c760:83:def:aced:fff0:0:2018]:443. Received 2 certificate(s), first certificate had names “mail.vasarhelyanno.hu, vasarhelyanno.hu, www.vasarhelyanno.hu”
    Domain: api.vasarhelyanno.hu
    Detail: Incorrect validation certificate for tls-sni-01 challenge.
    Requested
My web server is (include version): apache2 2.4.34-1
The operating system my web server runs on is (include version): ubuntu 16.04.1
The error is generating due to tls-sni-01, while I’m not sure why it’s generating the error, tls-sni-01 has been disabled for new domains for security purposes (however this is not related to your domain)
There’s one easy way to resolve this…
try issueing the certificate with sudo certbot certonly --preferred-challenge http -d api.vasarhelyanno.hu
after a successful issuerance, for future renewals, just run sudo certbot renew (as usual)
Thank you
One possibility is that the api subdomain has been moved to a separate server but that the IPv6 DNS records haven't been updated accordingly.
This is a good tip. (Don't forgot the --apache.) The version of Certbot will need to be new enough to have HTTP-01 support in the Apache plugin!
Thank you, but not worked:
certbot --apache certonly --preferred-challenge http -d api.vasarhelyanno.hu
http-01 challenge for api.vasarhelyanno.hu
Failed authorization procedure. api.vasarhelyanno.hu (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://api.vasarhelyanno.hu/.well-known/acme-challenge/CsWtTOu429q45jXhiKnRKlF7gZpGyX-n0olVNcdT2Mo: "
404 Not Found
Not Found
<p"
Hi @kellej
@schoen is right, your IPV6 records serve different content compare to IPV4 record…
https://letsdebug.net/api.vasarhelyanno.hu/3175
Please try to remove the IPV6 record and re run the certbot, then it should be working correctly…
Thank you
Or even better: point it to the correct IPv6 address if the current server has a working IPv6 connection. IPv6 is the future of the internet, removing it permanently would be, personally, not correct.
Removing it temporary for debugging purposes is of course not a problem.
