Not able to stop using TLS-SNI-01
Following the instructions in the pinned article How to stop using TLS-SNI-01 with Certbot has not worked. When it tries to renew, it still uses TLS-SNI-01.
My domain is: complete-concrete-concise.com
I ran this command: certbot renew --dry-run
Processing /etc/letsencrypt/renewal/complete-concrete-concise.com.conf
Plugins selected: Authenticator webroot, Installer apache
http-01 challenge for complete-concrete-concise.com
http-01 challenge for faqbite.com
http-01 challenge for www.complete-concrete-concise.com
http-01 challenge for www.faqbite.com
Waiting for verification…
Attempting to renew cert (complete-concrete-concise.com) from /etc/letsencrypt/renewal/complete-concrete-concise.com.conf produced an unexpected error: Failed authorization procedure. faqbite.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://faqbite.com/.well-known/acme-challenge/VrbRmiuLEokpPxeo0EhT6SikR4xXSmURobKapmEXXSM [2600:3c03::f03c:91ff:fe37:dac2]: "\n<html lang=“en”>\n \n \n\n \n <meta charset=“UTF-8”>\n <meta name=“viewpor”, complete-concrete-concise.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://complete-concrete-concise.com/.well-known/acme-challenge/t7HMURPx4gQcv254aahEfb3nbc2_CZ4FLAAwoJDY9N4 [2606:4700:30::681c:196f]: "\n\n\n<html lang=“en-US”>\n\n<meta name=“google-site-verification” content=“M6dlOwdAGrtkkzWpMabe6CDvxIm4TBbv4pRP”, www.complete-concrete-concise.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://complete-concrete-concise.com/.well-known/acme-challenge/2jTfLUh_q_NUb8kW_8vzJZp58j261ciQji5ZBx2I8t4 [2606:4700:30::681c:196f]: "\n\n\n<html lang=“en-US”>\n\n<meta name=“google-site-verification” content=“M6dlOwdAGrtkkzWpMabe6CDvxIm4TBbv4pRP”, www.faqbite.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://faqbite.com/.well-known/acme-challenge/PfatuRF8RjWKqr_hAgunR7M7P1PY-hd8bHG_MdtL72c [2600:3c03::f03c:91ff:fe37:dac2]: "\n<html lang=“en”>\n \n \n\n \n <meta charset=“UTF-8”>\n <meta name=“viewpor”. Skipping.
/etc/letsencrypt/live/complete-concrete-concise.com/fullchain.pem (failure)
Server version: Apache/2.4.29 (Ubuntu)
Server built: 2018-10-10T18:59:25
Distributor ID: Ubuntu
Description: Ubuntu 18.04.2 LTS
Release: 18.04
Codename: bionic
My hosting provider, if applicable, is: Linode
I can login to a root shell on my machine (yes or no, or I don’t know): |Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.28.0
My renewal config file contents are:
renew_before_expiry = 30 days
version = 0.28.0
archive_dir = /etc/letsencrypt/archive/complete-concrete-concise.com
cert = /etc/letsencrypt/live/complete-concrete-concise.com/cert.pem
privkey = /etc/letsencrypt/live/complete-concrete-concise.com/privkey.pem
chain = /etc/letsencrypt/live/complete-concrete-concise.com/chain.pem
fullchain = /etc/letsencrypt/live/complete-concrete-concise.com/fullchain.pem
[renewalparams]
account = fd262b6b4be9e611e9797eb2cdf5674a
authenticator = webroot
installer = apache
webroot_path = /var/www/complete-concrete-concise.com/public_html,
[[webroot_map]]
faqbite.com = /var/www/complete-concrete-concise.com/public_html
www.faqbite.com = /var/www/complete-concrete-concise.com/public_html
complete-concrete-concise.com = /var/www/complete-concrete-concise.com/public_html
www.complete-concrete-concise.com = /var/www/complete-concrete-concise.com/public_html
Why do you think so? From your output, it is using HTTP-01:
More likely is that your webroots are not working.
You might give the Apache authenticator a chance, it might instantly solve your problems:
certbot renew -a apache --dry-run
Hi @richardsplanet
checked that domain and the www - version:
You have 4 ip addresses, but all looks good. In the end, every request http + /.well-known/acme-challenge/unknown-filename is redirected to https + non-www + /.well-known/acme-challenge/unknown-filename, this is good (checked with complete-concrete-concise.com - Make your website better - DNS, redirects, mixed content, certificates - but the output is very long).
The last row is ok:
So your webroot must be wrong or there are additional definitions.
Create the two subdirectories
/var/www/complete-concrete-concise.com/public_html/.well-known/acme-challenge
there a file (file name 1234) and try to load this file via
http://complete-concrete-concise.com/.well-known/acme-challenge/1234
and your other domains.
Trying
results in the same output.
Probably because I am not well versed in everything letsencrypt and certbot are doing that I assumed that HTTP-01 was related to TLS-SNI-01 and was expecting to see HTTP-02
That was interesting, I get a 404 error. I know this worked the last time I had a problem and was asked to created this file.
I think it might also be due to Cloudflare.
If Cloudflare is talking to your server over HTTPS, then the Apache authenticator might not work.
To confirm this, you can temporarily disable Cloudflare (disable the "orange cloud" in the DNS manager) on your domains and try again.
Alternatively, you will need to figure out how to properly setup your web roots to the correct directories so that it succeeds:
For each of your domains, you should be able to create /var/www/{domain}/public_html/.well-known/acme-challenge/test.txt and be able to access them in the browser at http://{domain}/.well-known/acme-challenge/test.txt.
In the above they seem to all point to the same directory, which doesn't seem correct.
Then your webroot may be wrong.
Or you have additional definitions (location), that moves /.well-known/acme-challenge to another internal directory.
So check your VirtualHost - definitions or share these files.
Disabling Cloudflare and running
produces the expected output.
As for the [[webroot_map]] that was set up by certbot or letsencrypt. The only change I made was - almost 3 months ago - to change the authenticator to webroot (that was done under instruction to a previous help request).
I have no problem scrapping and regenerating the file (if that is possible).
You can directly modify this file to set the correct webroot for each respective domain. It might take some trial and error (and could depend on your .htaccess file as well).
You need to be able to reach files created in $WEBROOT/.well-known/acme-challenge/ from your browser.
It's worth solving - having to disable Cloudflare just to do renewal is not a good state of affairs :frowning: .
I'm going to need a bit of hand holding on this or a pointer to the relevant documentation.
I just had a look in my apache error.log and noticed the following (this was 3 hours before I asked my question):
[Thu Feb 21 06:37:48.284803 2019] [core:crit] [pid 12439:tid 139978671609600] (13)Permission denied: [client 172.68.34.77:49632] AH00529: /var/www/complete-concrete-concise.com/public_html/.well-known/acme-challenge/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable and that '/var/www/complete-concrete-concise.com/public_html/.well-known/acme-challenge/' is executable, referer: http://complete-concrete-concise.com/.well-known/acme-challenge/PMqWmd-KdA7VZ8JCpFdDuGWR6KD0LTmzYW6pgMUmIUE
I locked down access to .htaccess with the rule:
<Files ~ "^\.ht">
  Order allow,deny
  Deny from all
</Files>
so this might be causing the problem or part of the problem.
It turns out that this problem you experience with Cloudflare + the Apache authenticator (-a apache) is actually fixed since Certbot 0.31.
Unfortunately the Ubuntu 18.04 PPA doesn’t have an updated version yet, but it should do by the time your next renewal comes around. At that point you should be able to do:
and from then on, it will remember your choice and work automatically.
You can also use certbot-auto to always run the latest version, but in your case I would suggest just sticking with the Ubuntu PPA and upgrading once it becomes available.
Thanks for letting me know.
