Hello,
I get the following error when trying to run ./certbot-auto --apache
An unexpected error occurred: The request message was malformed :: Error creating new order :: Name does not end in a public suffix
I set the path using following in second attempt ./certbot-auto --apache --apache-challenge-location /etc/apache2
I get the same error when activating all domains and subdomains
Hi @Uneschewed
what's your domain name? Your domain name must end with a public suffix like .com, .de, .eu, .travel etc.
https://publicsuffix.org/
If not, you can't get a public certificate.
Where does it pull the name from, I have an external address
When you use --apache the names are pulled from your Apache configuration.
You can override this by specifying one or more names explicitly with the -d option.
When I run this command ignoring the extension which ends in .localhost, I select all others which end in .com
and I get this message on them
Failed authorization procedure. .com (http-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up A for
Then one domain has a wrong or missing dns entry.
Hello,
I have again installed certbot and now face an error which says
The apache plugin is not working; there may be problems with your existing configuration.
The error was: NoInstallationError(‘Could not find configuration root’,)
I try to run the command ./certbot-auto --apache --apache-challenge-location /etc/apache2
