Error running certbot
My domain is: computerrepairleeds.uk and www.computerrepairleeds.uk
and...
sudo certbot -d www.computerrepairleeds.uk, computerrepairleeds.uk --apache
An unexpected error occurred:
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x733ebfd0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
and...
Requested domain is not a FQDN because it contains an empty label.
My web server is (include version): Server version: Apache/2.4.52 (Raspbian)
Server built: 2022-01-03T21:27:14
The operating system my web server runs on is (include version): No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
My hosting provider, if applicable, is: godaddy.com
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.6.0
I have 2 domains already registered with certbot, which are www.severindouble.com and severindouble.com. I am wanting to ssl the domains www.computerrepairleeds.uk and computerrepairleeds.uk, but just leave www.severindouble.com and severindouble.com as they already have a certificate, but also allow access to the same site with computerrepairleeds.uk and www.computerrepairleeds.uk
Thanks for your help beforehand
That's a DNS issue.
What shows?
nslookup acme-v02.api.letsencrypt.org
cat /etc/resolv.conf
mmmm. Cheers for getting back to us. On running the command: nslookup acme-v02.api.letsencrypt.orgI get the response: -bash: nslookup: command not found
Upon running the command: cat /etc/resolv.confI get: nameserver 192.168.0.10.
I think I do vaguely remember messing about with this file and the hostname file as (if I remember correctly) I was trying to get sendmail working with a relay server, or at least trying to get emails sent from the raspberry pi box into (at the very least) the spam box of gmail
Thanks again
How about?:
dig +short acme-v02.api.letsencrypt.org
I think that part might be to remove the space after the comma. e.g. -d www.computerrepairleeds.uk,computerrepairleeds.uk - I think they're other syntax variations you can use like -d www.computerrepairleeds.uk -d computerrepairleeds.uk
Surprisingly, this worked! Certbot is now asking which virtual server configuration I want to use. I have tried all 3, but I get the following:
sudo certbot -d www.computerrepairleeds.uk,computerrepairleeds.uk --apache
(ref: /etc/letsencrypt/renewal/www.computerrepairleeds.uk.conf)
What would you like to do?
2: Renew & replace the certificate (may be subject to CA rate limits)
Deploying certificate
We were unable to find a vhost with a ServerName or Address of www.computerrepairleeds.uk.
Which virtual host would you like to choose?
1: 000-default-le-ssl.conf | Multiple Names | HTTPS | Enabled
2: 000-default-le-ssl.conf | www.severindouble.com | | Enabled
3: 000-default.conf | www.severindouble.com | | Enabled
Select the appropriate number [1-3] then [enter] (press 'c' to cancel): 1
Successfully deployed certificate for www.computerrepairleeds.uk to /etc/apache2/sites-enabled/000-default-le-ssl.conf
We were unable to find a vhost with a ServerName or Address of computerrepairleeds.uk.
Select the appropriate number [1-3] then [enter] (press 'c' to cancel): 2
The selected vhost would conflict with other HTTPS VirtualHosts within Apache. Please select another vhost or add ServerNames to your configuration.
Could not install certificate
NEXT STEPS:
  • The certificate was saved, but could not be installed (installer: apache). After fixing the error shown below, try installing it again by running:
    certbot install --cert-name www.computerrepairleeds.uk
VirtualHost not able to be selected.
I then added the following lines in /etc/apache2/sites-enabled/000-default.conf and got the following:
RewriteCond %{SERVER_NAME} =computerrepairleeds.uk
ServerAlias www.computerrepairleeds.uk
Some rewrite rules copied from /etc/apache2/sites-enabled/000-default.conf were disabled in the vhost for your HTTPS site located at /etc/apache2/sites-available/000-default-le-ssl.conf because they have the potential to create redirection loops.
Successfully deployed certificate for www.computerrepairleeds.uk to /etc/apache2/sites-available/000-default-le-ssl.conf
1: 000-default.conf | Multiple Names | | Enabled
2: 000-default-le-ssl.conf | Multiple Names | HTTPS | Enabled
Successfully deployed certificate for computerrepairleeds.uk to /etc/apache2/sites-available/000-default-le-ssl.conf
Congratulations! You have successfully enabled HTTPS on https://www.computerrepairleeds.uk and https://computerrepairleeds.uk
...but I now get a "security risk ahead" warning when I try and access https://severindouble.com. Also I have added the following lines to .htaccess:
RewriteCond %{HTTPS} !=on
RewriteCond %{HTTP_HOST} ^(www.)?computerrepairleeds.uk
RewriteRule ^/?(.*) https://%{SERVER_NAME}/$1 [R,L]
...and that does the trick of redirecting computerrepairleeds.uk and www.computerrepairleeds.uk to https://
Thanks for all your help thus far and beforehand
Sorry. I forgot to say, basically I want www.severindouble.com, severindouble.com, www.computerrepairleeds.uk and computerrepairleeds.uk all to point at the same web site and have ssl certificates. Cheers
sorry command not found again
Hi there again. I have sorted it! I just ran the certbot command with all the domain names, thus:
sudo certbot -d www.computerrepairleeds.uk,computerrepairleeds.uk,www.severindouble.com,severindouble.com --apache
Cheers
