Edit : Important things to note : before running apt update + upgrade the issue was : “The request message was malformed :: Method not allowed”
Woops my bad for -T here is the output
configuration file /etc/nginx/nginx.conf:
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/javascript text/xml applicati on/xml application/xml+rss text/javascript;
# Virtual Host Configs
#mail {
# See sample authentication script at:
# auth_http localhost/auth.php;
# pop3_capabilities “TOP” “USER”;
# imap_capabilities “IMAP4rev1” “UIDPLUS”;
listen localhost:110;
protocol pop3;
proxy on;
listen localhost:143;
protocol imap;
proxy on;
configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
configuration file /etc/nginx/modules-enabled/50-mod-http-image-filter.conf:
configuration file /etc/nginx/modules-enabled/50-mod-http-xslt-filter.conf:
configuration file /etc/nginx/modules-enabled/50-mod-mail.conf:
configuration file /etc/nginx/modules-enabled/50-mod-stream.conf:
configuration file /etc/nginx/mime.types:
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
configuration file /etc/nginx/sites-enabled/default:
You should look at the following URL’s in order to grasp a solid understanding
of Nginx configuration files in order to fully unleash the power of Nginx.
In most cases, administrators will remove this file from sites-enabled/ and
leave it as reference inside of sites-available where it will continue to be
updated by the nginx packaging team.
This file will automatically load configuration files provided by other
applications, such as Drupal or Wordpress. These applications will be made
available underneath a path with that package name, such as /drupal8.
Please see /usr/share/doc/nginx-doc/examples/ for more detailed examples.
Default server configuration
listen 80 default_server;
# SSL configuration
root /var/www/html;
server_name _;
try_files $uri $uri/ =404;
#location ~ \.php$ {
# include snippets/fastcgi-php.conf;
# # With php-fpm (or other unix sockets):
# fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
# # With php-cgi (or other tcp sockets):
# fastcgi_pass 127.0.0.1:9000;
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
Virtual Host configuration for example.com
You can move that to a different file under sites-available/ and symlink that
to sites-enabled/ to enable it.
#server {
listen 80;
listen [::]:80;
root /var/www/example.com;
index index.html;
configuration file /etc/nginx/sites-enabled/irice.fr:
Odoo servers
upstream odoo {
server 127.0.0.1:3697;
upstream odoochat {
server 127.0.0.1:8072;
HTTP -> HTTPS
listen 80;
server_name www.irice.fr irice.fr;
include snippets/letsencrypt.conf;
return 301 https://irice.fr$request_uri;
WWW -> NON WWW
listen 443 ssl http2;
server_name www.irice.fr;
ssl_certificate /etc/letsencrypt/live/irice.fr/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/irice.fr/privkey.pem;
ssl_trusted_certificate /etc/letsencrypt/live/irice.fr/chain.pem;
include snippets/ssl.conf;
server_name irice.fr;
proxy_read_timeout 720s;
proxy_connect_timeout 720s;
proxy_send_timeout 720s;
# Proxy headers
proxy_set_header X-Forwarded-Host $host;
# SSL parameters
# log files
access_log /var/log/nginx/odoo.access.log;
error_log /var/log/nginx/odoo.error.log;
# Handle longpoll requests
location /longpolling {
proxy_pass http://odoochat;
# Handle / requests
proxy_redirect off;
proxy_pass http://odoo;
# Cache static files
location ~* /web/static/ {
proxy_cache_valid 200 90m;
proxy_buffering on;
expires 864000;
# Gzip
gzip_types text/css text/less text/plain text/xml application/xml application/json application/ javascript;
gzip on;
configuration file /etc/nginx/snippets/letsencrypt.conf:
location ^~ /.well-known/acme-challenge/ {
allow all;
root /var/lib/letsencrypt/;
default_type “text/plain”;
try_files $uri =404;
configuration file /etc/nginx/snippets/ssl.conf:
ssl_dhparam /etc/ssl/certs/dhparam.pem;
ssl_session_timeout 1d;
ssl_session_cache shared:SSL:50m;
ssl_session_tickets off;
ssl_ciphers ‘ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA25 6:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES 128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-EC DSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-A ES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-R SA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA25 6:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS’;
ssl_stapling on;
ssl_stapling_verify on;
resolver 8.8.8.8 8.8.4.4 valid=300s;
resolver_timeout 30s;
add_header Strict-Transport-Security “max-age=15768000; includeSubdomains; preload”;
add_header X-Frame-Options SAMEORIGIN;
add_header X-Content-Type-Options nosniff;
I read the user guide and managed to understand that was my path " --webroot -w /var/lib/letsencrypt/ what is not working in this case ?
Oh ok I understand it, Vhost is what I call server Block that’s why I missunderstood
This looks ok to me
