【Error】Certbot does not renew after expiration
Screenshot_20180807_082615
I saw this message, but after renewing with certbot the certificate will not be updated.
git.076.ne.jp
certbot renew
root@git:~# certbot renew
Processing /etc/letsencrypt/renewal/git.076.ne.jp.conf
Cert not yet due for renewal
  /etc/letsencrypt/live/git.076.ne.jp/fullchain.pem (skipped)
No renewals were attempted.
nginx 1.12.1 (Gitlab)
Debian 9.4
My server
Yes
No
Hi @TechnicalSuwako
you have two active certificates:
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:false;domain:git.076.ne.jp&lu=cert_search
One from 2018-07-07, one from 2018-08-07.
So your website used an old certificate. Check your certificates with
Certbot certificates
and use the path of the newer certificate in your nginx - configuration file.
What does “certbot certificates” output?
If you reload Nginx – e.g. “service nginx reload” or “systemctl reload nginx” – does that help?
What are Nginx’s ssl_certificate and ssl_certificate_key settings?
After commanding “gitlab-ctl restart nginx”, the problem cured.
Thank you very much for your help quickly.
In that case, you might want to add that as a deploy hook in your Certbot configuration, so that it will be run automatically when your certificates are renewed in the future.
