My domain is:unifi.portcitydata.com
I ran this command: sudo certbot renew
/etc/letsencrypt/live/portcitydata.com/fullchain.pem expires on 2020-09-01 (skipped)
/etc/letsencrypt/live/unifi.portcitydata.com/fullchain.pem expires on 2020-09-01 (skipped)
No renewals were attempted.
The operating system my web server runs on is (include version): Ubuntu 18.04 LTS
My hosting provider, if applicable, is: Digital Ocean
I can login to a root shell on my machine (yes or no, or I donât know): Yes
Iâm using a control panel to manage my site (no, or provide the name and version of the control panel): No
The version of my client is (e.g. output of certbot --version or certbot-auto --version if youâre using Certbot): 0.27.0
Can you try to execute the below command?
sudo systemctl restart nginx
I think you used certonly when issuing the certificate, which means your certificate renewal and since certbot didnât know what server you used on, it didnât apply the certificate to nginx. A simple reload would fix this issue.
P.S. For future reference, try certbot renew -a nginx (which should specify the authenticator to nginx web server.)
I had actually restarted the whole server before making this post. That would have restarted nginx.
Could we also see the output of sudo certbot certificates?
Found the following certs:
Certificate Name: portcitydata.com
Domains: portcitydata.com
Expiry Date: 2020-09-01 11:15:50+00:00 (VALID: 54 days)
Certificate Path: /etc/letsencrypt/live/portcitydata.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/portcitydata.com/privkey.pem
Certificate Name: unifi.portcitydata.com
Domains: unifi.portcitydata.com
Expiry Date: 2020-09-01 11:15:58+00:00 (VALID: 54 days)
Certificate Path: /etc/letsencrypt/live/unifi.portcitydata.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/unifi.portcitydata.com/privkey.pem
I figured it out. I had a cron job set to run a script that imported the updated cert shortly after cerbot renew runs but it was not running for some reason. I manually ran it and all is well. I just have to work out why the cron job was not running now.
Thanks for the help!!!
Great! You might want to look at Certbotâs --deploy-hook option, which will let Certbot initiate a task to deploy a new certificate immediately after itâs saved (assuming your security model makes that appropriate).
