Hello And thank you for taking the time to read
I have a domain giladsky.com and a subdomain chat.giladsky.com
everything was working fine, i have a weekly cronjob to renew certificates, yesterday on my subdomain i received an error 429, if i understood correct i did not hit the rate limit
this is from my log file
Create new order error. Le_OrderFinalize not found. {
"type": "urn:ietf:params:acme:error:rateLimited",
"detail": "Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/",
"status": 429
and also i started to see this error
chown: changing ownership of '/var/www/letsencrypt/.well-known/acme-challenge/uTuEg4xH1SJUlb_0h_UN9zvmoFGDQTzNN6IBXEXFc1I':>
chown: changing ownership of '/var/www/letsencrypt/.well-known/acme-challenge': Operation not permitted
chown: changing ownership of '/var/www/letsencrypt/.well-known': Operation not permitted
even though when checking permission all is set like before
Thank you for taking the time if you can please help me
Thank you
Gilad
