This link is changed because of security reasons …
I always get the ERR-EMPTY RESPONSE on url that has either query string or after the file added a permalink.
I need to send extra data=token to reset password via email and I do not want the user adds it manually.
The site works perfect without query string or permalink, but when I try to submit data there is no green lock anymore and I tried it in FF and Chrome.
The empty response is probably a backend web application error (where the web application fails to return content for the web server to serve as a reply, perhaps due to crashing). It’s not likely to be a cryptographic error with your certificates. I’d suggest looking at your web server error logs to see if an error is identified there.
It worked before I had ssl, and it does work if I do not submit a query string or permalink in url or I do not use https … I have no clue what can be wrong.
