ERR_CONNECTION_REFUSED after let's encrypt
My domain is: iakzscloud.ddns.net
Certificate is saved at: /etc/letsencrypt/live/iakzscloud.ddns.net/fullchain.pem
Key is saved at: /etc/letsencrypt/live/iakzscloud.ddns.net/privkey.pem
This certificate expires on 2023-10-11.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
Deploying certificate
Successfully deployed certificate for iakzscloud.ddns.net to /etc/apache2/sites-enabled/nextcloud-le-ssl.conf
Error while running apache2ctl graceful.
httpd not running, trying to start
Action 'graceful' failed.
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
(98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
(98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
AH00015: Unable to open logs
Unable to restart apache using ['apache2ctl', 'graceful']
An error occurred and we failed to restore your config and restart your server. Please post to Help - Let's Encrypt Community Support with details about your configuration and this error you received.
Encountered exception during recovery: certbot.errors.MisconfigurationError: Error while running apache2ctl graceful.
NEXT STEPS:
  • The certificate was saved, but could not be installed (installer: apache). After fixing the error shown below, try installing it again by running:
    certbot install --cert-name iakzscloud.ddns.net
My web server is (include version): apache2
The operating system my web server runs on is (include version): ubuntu server 22.04.2 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.6.0
Hello @, welcome to the Let's Encrypt community. :slightly_smiling_face:
Your HTTPS Port 443 is Closed (edit: from IPv4).
$ nmap -Pn -p80,443 iakzscloud.ddns.net
Starting Nmap 7.80 ( https://nmap.org ) at 2023-07-13 15:46 UTC
Nmap scan report for iakzscloud.ddns.net (191.112.124.173)
Host is up (0.18s latency).
rDNS record for 191.112.124.173: 191-112-124-173.baf.movistar.cl
PORT    STATE  SERVICE
80/tcp  open   http
443/tcp closed https
Nmap done: 1 IP address (1 host up) scanned in 0.54 seconds
i have it open on my router
OK, but on the web server (i.e. apache) is port 443 being served?
Seems like potentially an issue with apache configuration.
Kindly wait for more knowledgeable Let's Encrypt community volunteers to assist.
on ports.conf there's the port 443
Sorry, I dont know too much about this. I'm new
Can you show result of this
sudo netstat -pant | grep -Ei ':80|:443' | grep -i listen
tcp6 0 0 :::80 :::* LISTEN 3129/httpd
FYI - I am only able to check from IPv4 most of the time.
This looks like IPv4 only is being handled with the above.
what i need to do?
Read the manual on your router to see how to handle IPv6 as well.
Can you reboot your server?
How did you install Apache? On my Ubuntu it is called apache2 but yours is showing httpd
This is not pertinent now. They don't have an IPv6 address in their DNS.
Thanks @MikeMcQ for checking that! :slight_smile:
Yes (i'm rebooting it right now)
I followed a nextcloud tutorial and installed it with sudo apt install apache2
After reboot let us know when done and we'll check Apache some more.
It was working until i did a restart like 10 minutes ago to see if the opcache configuration worked.
This is looking better.
Starting Nmap 7.80 ( https://nmap.org ) at 2023-07-13 16:11 UTC
Host is up (0.19s latency).
PORT    STATE SERVICE
80/tcp  open  http
443/tcp open  https
Nmap done: 1 IP address (1 host up) scanned in 0.27 seconds
OK, it rebooted
And now it is Closed again.
Starting Nmap 7.80 ( https://nmap.org ) at 2023-07-13 16:12 UTC
PORT    STATE  SERVICE
80/tcp  open   http
Nmap done: 1 IP address (1 host up) scanned in 0.28 seconds
