DV SAN cert is stuck for sometime now
CN: cert00055-azurecdn.akamaized.net
CA comments: 2020-04-22 12:59 GMT Let’s Encrypt: Order\u0027s status (\
Logs on Akamai CPS shows this:
ERROR com.akamai.cps.work_elements.le.LeRetrieveCertificateActionBean - LeErrorReport(statusCode=403, type=urn:ietf:params:acme:error:orderNotReady, detail=Order’s status (“invalid”) is not acceptable for finalization)
New Domain that was added here: www.sufinama.org.
It is also noticed that the CA comments is from future data :smiley:
Can you tell us if the job is still running or something else is happening?
Hi @Subhasish
that ACME client is buggy.
If the order status is invalid, that client should check that instead of sending the finalize command.
-->> Update your buggy client or use another client.
And find the reason why the order is invalid.
