Cert issue , certificate stuck in pending state
My domain is: www.carrefouruae.com
We getting a message"2020-07-03 16:29 GMT Let’s Encrypt: Order\u0027s status ("
You need to ask Akamai to look into it.
Let’s Encrypt orders don’t get “stuck” in a pending state, this is something that is local to the Akamai ACME client and they would be able to check the status of your order internally.
The error message Akamai gets back from LE is
{“message”:“urn:ietf:params:acme:error:caa”,“detail”:“Error finalizing order :: While processing CAA for www.carrefourjordan.com: DNS problem: SERVFAIL looking up CAA for carrefourjordan.com - the domain\u0027s nameservers may be malfunctioning”}
Order URL: https://acme-v02.api.letsencrypt.org/acme/order/131/4110433235
What is the proper lookup we should do for CAA records so we can avoid this issue? I am assured that none of the domains in this order have CAA records.
Akamai retried this with a new order and this time it succeeded. Nothing changed about the CAA records, as far as I know.
New order URL: https://acme-v02.api.letsencrypt.org/acme/order/131/4114006495
Hi @tiday
checking your domain that's curious. Unboundtest - no error, not non-www, not www. Same with a local unbound-instance.
But checking your domain via https://check-your-website.server-daten.de/?q=carrefourjordan.com there is a problem visible.
One name server is buggy:
Some X - Warnings:
X Fatal error: Nameserver doesn't support TCP connection: keu.carrefour.com / 213.137.173.17: Timeout
X Fatal error: Nameserver doesn't support TCP connection: keu.carrefour.com / 2a00:2000:4701:d::1: Timeout
X Nameserver Timeout checking Echo Capitalization: keu.carrefour.com / 213.137.173.17
X Nameserver Timeout checking Echo Capitalization: keu.carrefour.com / 2a00:2000:4701:d::1
X Nameserver Timeout checking EDNS512: keu.carrefour.com / 213.137.173.17
X Nameserver Timeout checking EDNS512: keu.carrefour.com / 2a00:2000:4701:d::1
So checking the CAA record if that name server is used -> Servfail. If other name servers used -> no problem.
