My domain is: gilliards.duckdns.org
I ran this command: sudo certbot -v --apache -d gilliards.duckdns.org
Domain: gilliards.duckdns.org
Type: connection
Detail: 68.132.55.4: Fetching http://gilliards.duckdns.org/.well-known/acme-challenge/Kd1mchCHMDejr5iCTk7ZfZTmEqIs2ZlDr2U608E_HXo: Timeout during connect (likely firewall problem)
Server version: Apache/2.4.57 (Ubuntu)
Server built: 2023-04-08T12:56:02
Ubuntu 22.04.2 LTS
Yes
No, I have sudo access
2.6.0
I've setup my firewall as :
80,443/tcp ALLOW Anywhere
443,8080/tcp ALLOW Anywhere
80,443/tcp (v6) ALLOW Anywhere (v6)
443,8080/tcp (v6) ALLOW Anywhere (v6)
Is there anything I'm missing?
Thank you in advance for any help you can provide.
Steve
