My domain is: cloud.awaresolucoes.com
cloud@cloud:~$ sudo certbot --apache
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
Requesting a certificate for cloud.awaresolucoes.com
Domain: cloud.awaresolucoes.com
Type: connection
Detail: 191.253.31.56: Fetching http://cloud.awaresolucoes.com/.well-known/acme-challenge/gZrK5F04YZMtHBn7bJ3J69hxspb2S88usTGuXD-0iNo: Timeout during connect (likely firewall problem)
cloud@cloud:~$
My web server is (include version): apache, Version: 2.4.58-1ubuntu8.5
The operating system my web server runs on is (include version): Ubuntu 24.04.1 LTS
My hosting provider, if applicable, is: Vercel (Subdomain)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 3.0.1.
There are issues with my ISP router: I cannot directly open ports 443 and 80. I can only redirect them internally as follows:
- Externally: port 8080 -> redirects to 80
- Externally: port 8443 -> redirects to 443
Is there a way to resolve this issue and successfully generate the SSL certificate?
