Drupal 8 http not redirecting to https - Solved
Installed letsencrypt no problem
Two websites involved with same sites-enabled content
One forum.ebhc2020.eu drops straight into https
The other ebhc2020.eu does not unless https:// is added. It gives an apache ubuntu default page
I have altered the .htaccess file to include the recommended re-write commands, which were included in the config file
My domain is:ebhc2020.eu
I ran this command: certbot --apache
It produced this output:http and https
My web server is (include version): apache2 latest
The operating system my web server runs on is (include version):ubuntu 18.04
My hosting provider, if applicable, is:Linode
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
Hi @Ragodin
create a vHost, which handles port 80
https://httpd.apache.org/docs/2.4/vhosts/examples.html
And there a RewriteCond
https://httpd.apache.org/docs/2.4/mod/mod_rewrite.html#rewriterule
to redirect http -> https.
Will have a go tomorrow, thanks
Well I tried it all creating a non-ssl configuration in sites-available and then using a2ensite then reloading apache but nothing happened apart from apache refusing to restart .
Then removed the lines
RewriteCond %{SERVER_NAME} =ebhc2020.eu [OR]
RewriteCond %{SERVER_NAME} =www.ebhc2020.eu
But leaving
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI}
Repeated the process and every thing worked
Thanks for pointing me in the right direction
