[Solved] Apache2 installation went perfect but https not working
as stated at https://certbot.eff.org/lets-encrypt/ubuntuxenial-apache
I did on:
Distributor ID: Ubuntu
Description: Ubuntu 16.04.4 LTS
Release: 16.04
Codename: xenial
and all worked well :slight_smile: at installation point
but When I go to site it doesn’t work :frowning:
I did restart apache2 server
in my apache I see two files:
000-default.conf 000-default-le-ssl.conf
I replaced real domain with example.com
000-default.conf
<VirtualHost :80>
# specifies what hostname must appear in the request’s Host: header to
#ServerName www.example.com
ServerName test.domain.com
DocumentRoot /var/www/test/html/web/
<Directory /var/www/test/html/web>
AllowOverride None
Order Allow,Deny
Allow from All
php_flag display_errors On
Options -MultiViews
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteRule ^(.
)$ app.php [QSA,L]
# Available loglevels: trace8, …, trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteCond %{SERVER_NAME} =test.domain.com
and for
# The ServerName directive sets the request scheme, hostname and port that # the server uses to identify itself. This is used when creating # redirection URLs. In the context of virtual hosts, the ServerName # specifies what hostname must appear in the request's Host: header to # match this virtual host. For the default virtual host (this file) this # value is not decisive as it is used as a last resort host regardless. # However, you must set it for any further virtual host explicitly. #ServerName www.example.com ServerName test.example.com ServerAdmin webmaster@localhost DocumentRoot /var/www/test/html/web/ AllowOverride None Order Allow,Deny Allow from All php_flag display_errors On Options -MultiViews RewriteEngine On RewriteCond %{REQUEST_FILENAME} !-f RewriteRule ^(.*)$ app.php [QSA,L] # Available loglevels: trace8, ..., trace1, debug, info, notice, warn, # error, crit, alert, emerg. # It is also possible to configure the loglevel for particular # modules, e.g. #LogLevel info ssl:warn
SSLCertificateFile /etc/letsencrypt/live/test.example.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/test.example.com/privkey.pem
433 on amazon wasn’t open :slight_smile: so fixed
