Double-wildcard certificates?
Is it possible to have one certificate to cover *.*.domain?
If not, can someone help me write some script to update them whether I need a new subdomain and cover all its subdomains?
It appears you meant to write *.*.domain but the asterisks got interpreted by the forum's markdown parser as an emphasis of the first dot. :smile:
No, it's not possible to issue a certificate with multiple wildcard labels. Additionally, it's only possible to have a wildcard label as a leftmost component. I.e this is also not possible: subsubdomain.*.example.net
I concur fully with @Nekit. There is nothing for certificates like what DNAME records do for DNS.
OK, is there at least an automated way to request one when needed?
Request one of what?
You've come to the wrong forum for free script writing help.
Yes, some acme clients support on demand certificates. Caddy is one example.
You will get several certificates, not one.
