Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: eduzz.com.br
I ran this command: sudo certbot -d eduzz.com.br
Certificate Name: eduzz.com.br
Domains: eduzz.com.br
Expiry Date: 2019-09-26 13:27:23+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/eduzz.com.br/fullchain.pem
Private Key Path: /etc/letsencrypt/live/eduzz.com.br/privkey.pem
My web server is (include version): Server version: Apache/2.4.6 (CentOS)
The operating system my web server runs on is (include version): NAME=“CentOS Linux”
VERSION=“7 (Core)”
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.34.2
When accessing https://www.eduzz.com.br and in “Advanced”: 'This server was unable to prove that it is www.eduzz.com.br. The security certificate is from api.eduzz.com . This may be caused by an incorrect configuration or by the interception of your connection by an attacker. ’
Hi @wexllen
checking your domain there are timeouts ( https://check-your-website.server-daten.de/?q=eduzz.com.br ):
And you have a redirect to the com domain. That domain has the correct certificate.
You use an Apache. Perhaps the wrong vHost is used.
What says
apachectl -S
Thanks for responding promptly @JuergenAuer . The output I get on apachectl -S is:
AH00112: Warning: DocumentRoot [/var/www/fabio.devzz.ninja] does not exist
VirtualHost configuration:
*:80 is a NameVirtualHost
default server api.eduzz.com (/etc/httpd/vhosts/api.eduzz.com.conf:1)
port 80 namevhost api.eduzz.com (/etc/httpd/vhosts/api.eduzz.com.conf:1)
port 80 namevhost appmobile.eduzz.com (/etc/httpd/vhosts/appmobile.eduzz.com.conf:1)
port 80 namevhost ip-172-32-31-177.ec2.internal (/etc/httpd/vhosts/default.conf:1)
port 80 namevhost www.eduzz.com.br (/etc/httpd/vhosts/eduzz.com.br.conf:1)
port 80 namevhost eduzz.com.br (/etc/httpd/vhosts/eduzz.com.br.conf:7)
port 80 namevhost eduzz.com (/etc/httpd/vhosts/eduzz.com.conf:1)
port 80 namevhost eduzz.info (/etc/httpd/vhosts/eduzz.info.conf:1)
alias www.eduzz.info
port 80 namevhost edz.la (/etc/httpd/vhosts/edz.la.conf:1)
alias edzz.la
port 80 namevhost edzz.la (/etc/httpd/vhosts/edzz.la.conf:1)
alias edzz.la
port 80 namevhost fabio.devzz.ninja (/etc/httpd/vhosts/fabio.devzz.ninja.conf:1)
port 80 namevhost g.eduzz.com (/etc/httpd/vhosts/g.eduzz.com.conf:1)
port 80 namevhost logzz.eduzz.com (/etc/httpd/vhosts/logzz.eduzz.com.conf:1)
port 80 namevhost my.eduzz.com (/etc/httpd/vhosts/my.eduzz.com.conf:1)
port 80 namevhost www.eduzz.com.br (/etc/httpd/vhosts/redirect.conf:1)
port 80 namevhost www.eduzz.com (/etc/httpd/vhosts/redirect.conf:6)
alias eduzz.com.br
port 80 namevhost www.eduzz.pt (/etc/httpd/vhosts/redirect.conf:16)
port 80 namevhost www.edz.la (/etc/httpd/vhosts/redirect.conf:21)
port 80 namevhost www.edzz.la (/etc/httpd/vhosts/redirect.conf:29)
port 80 namevhost files.eduzz.com (/etc/httpd/vhosts/redirect.conf:37)
port 80 namevhost edz.la (/etc/httpd/conf.d/le-redirect-edz.la.conf:1)
*:443 is a NameVirtualHost
default server api.eduzz.com (/etc/httpd/vhosts/api.eduzz.com.conf:14)
port 443 namevhost api.eduzz.com (/etc/httpd/vhosts/api.eduzz.com.conf:14)
port 443 namevhost appmobile.eduzz.com (/etc/httpd/vhosts/appmobile.eduzz.com.conf:14)
port 443 namevhost eduzz.com (/etc/httpd/vhosts/eduzz.com.conf:15)
port 443 namevhost eduzz.info (/etc/httpd/vhosts/eduzz.info.conf:16)
port 443 namevhost edz.la (/etc/httpd/vhosts/edz.la.conf:19)
port 443 namevhost edzz.la (/etc/httpd/vhosts/edzz.la.conf:18)
alias edzz.la
port 443 namevhost g.eduzz.com (/etc/httpd/vhosts/g.eduzz.com.conf:14)
port 443 namevhost logzz.eduzz.com (/etc/httpd/vhosts/logzz.eduzz.com.conf:14)
port 443 namevhost my.eduzz.com (/etc/httpd/vhosts/my.eduzz.com.conf:15)
port 443 namevhost www.edz.la (/etc/httpd/vhosts/redirect-le-ssl.conf:2)
port 443 namevhost www.edzz.la (/etc/httpd/vhosts/redirect-le-ssl.conf:12)
port 443 namevhost www.eduzz.com (/etc/httpd/vhosts/redirect-le-ssl.conf:22)
alias eduzz.com.br
port 443 namevhost ip-172-32-31-177.ec2.internal (/etc/httpd/conf.d/ssl.conf:56)
ServerRoot: "/etc/httpd"
Main DocumentRoot: "/var/www/default"
Main ErrorLog: "/etc/httpd/logs/error_log"
Mutex authdigest-opaque: using_defaults
Mutex proxy-balancer-shm: using_defaults
Mutex authdigest-client: using_defaults
Mutex proxy: using_defaults
Mutex authn-socache: using_defaults
Mutex default: dir="/run/httpd/" mechanism=default
PidFile: "/run/httpd/httpd.pid"
Define: _RH_HAS_HTTPPROTOCOLOPTIONS
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="apache" id=48
Group: name="apache" id=48
[root@ip-172-32-31-177 centos]#
[root@ip-172-32-31-177 centos]# apachectl -S
alias edzz.la
alias edzz.la
alias eduzz.com.br
alias edzz.la
alias eduzz.com.br
Define: DUMP_VHOSTS
There you see the problem:
The combination of port 80 and eduzz.com.br is duplicated. One own vHost, one alias.
Remove one of these entries.
Perhaps one vHost with non-www and www.
Same with all port 443 vHosts.
Every combination of port and domain name should be unique.
Thanks for the @JuergenAuer guidelines. Provisionally what worked for me was to generate a certificate with “www” next to the domain name.
system
Closed
August 1, 2019, 1:07pm
8
