Hm. Then i do not get it... Let me show you the files:
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =yoffi.eatdoori.dev [OR]
RewriteCond %{SERVER_NAME} =kokumy.eatdoori.dev [OR]
RewriteCond %{SERVER_NAME} =eatdoori.delivery [OR]
RewriteCond %{SERVER_NAME} =eatdoori.dev
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
and the 000-ssl
<IfModule mod_ssl.c>
<VirtualHost *:443>
# modules, e.g.
ServerName eatdoori.dev
ServerAlias eatdoori.delivery
ServerAlias kokumy.eatdoori.delivery
ServerAlias yoffi.eatdoori.delivery
ServerAlias kokumy.eatdoori.dev
ServerAlias yoffi.eatdoori.dev
SSLCertificateFile /etc/letsencrypt/live/eatdoori.dev-0001/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/eatdoori.dev-0001/privkey.pem
</VirtualHost>
</IfModule>
<VirtualHost *:80>
# modules, e.g.
RewriteEngine on
# Some rewrite rules in this file were disabled on your HTTPS site,
# because they have the potential to create redirection loops.
# RewriteCond %{SERVER_NAME} =kokumy.thx4.com [OR]
# RewriteCond %{SERVER_NAME} =eatdoori.thx4.com [OR]
# RewriteCond %{SERVER_NAME} =yoffi.thx4.com [OR]
# RewriteCond %{SERVER_NAME} =thx4.com
# RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
</IfModule>
