Does not exist or not in the directory
My domain is: a0752017.xsph.ru/
I ran this command: Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Try the new cross-platform PowerShell Install PowerShell on Windows, Linux, and macOS - PowerShell | Microsoft Learn
PS C:\WINDOWS\system32> certbot run
Saving debug log to C:\Certbot\log\letsencrypt.log
Certbot doesn't know how to automatically configure the web server on this system. However, it can still get a certificate for you. Please run "certbot certonly" to do so. You'll need to manually configure your web server to use the resulting certificate.
PS C:\WINDOWS\system32> certbot certonly
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): a0752017.xsph.ru
Requesting a certificate for a0752017.xsph.ru
Input the webroot for a0752017.xsph.ru: (Enter 'c' to cancel): /home/a0752017 / domains /a0752017.xsph.ru/
/home/a0752017 / domains /a0752017.xsph.ru/ does not exist or is not a directory
Input the webroot for a0752017.xsph.ru: (Enter 'c' to cancel): home/a0752017/domains
home/a0752017/domains does not exist or is not a directory
Input the webroot for a0752017.xsph.ru: (Enter 'c' to cancel): /home/a0752017/domains/a0752017.xsph.ru/public_html/
/home/a0752017/domains/a0752017.xsph.ru/public_html/ does not exist or is not a
directory
Input the webroot for a0752017.xsph.ru: (Enter 'c' to cancel): ftp. a0752017.xsph.ru
ftp. a0752017.xsph.ru does not exist or is not a directory
Input the webroot for a0752017.xsph.ru: (Enter 'c' to cancel): https://cp.sprinthost.ru/customer/files/manager?p=left&path%5Bleft%5D=eyJlbmNvZGluZyI6IlVURi04IiwiYmFzZTY0IjoiTDJodmJXVXZZVEEzTlRJd01UY3ZaRzl0WVdsdWN5OWhNRGMxTWpBeE55NTRjM0JvTG5KMSJ9&page%5Bleft%5D=1&sort%5Bleft%5D=name_asc
Input the webroot for a0752017.xsph.ru: (Enter 'c' to cancel): https://cp.sprinthost.ru/customer/files/manager?p=left&path%5Bleft%5D=eyJlbmNvZGluZyI6IlVURi04IiwiYmFzZTY0IjoiTDJodmJXVXZZVEEzTlRJd01UY3ZaRzl0WVdsdWN5OWhNRGMxTWpBeE55NTRjM0JvTG5KMUwzQjFZbXhwWTE5b2RHMXMifQ%3D%3D&page%5Bleft%5D=1&sort%5Bleft%5D=name_asc
Welcome to the community @inventorymanagement
Can you describe your server setup? Because a request to your domain says "openresty" is the server which is an nginx based server. Yet, the 404 error page says it is Apache.
Which of these servers is processing the HTTP challenge request?
curl -i a0752017.xsph.ru/.well-known/acme-challenge/TestForum123
HTTP/1.1 404 Not Found
Server: openresty
Date: Thu, 08 Dec 2022 17:51:28 GMT
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<title>404 Not Found</title>
<p>The requested URL /.well-known/acme-challenge/TestForum123 was not found on this server.</p>
<address>Apache/2.4.6 Server at a0752017.xsph.ru Port 80</address>
(some parts omitted from html error page)
