My domain is: ishere.com
It produced this output: THe requested dns-dnsmadeeasy plugin does not appear to be installed
My web server is (include version): apache24
The operating system my web server runs on is (include version): Freebsd 14.0 release p6
My hosting provider, if applicable, is: Datacate
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.9
Question I have is regarding the correct plugin for Freebsd .. I see a few comments regarding some. Freebsd has this one and wondering if anyone has used and can recommend to use or not use. ?
It appears that I've had someone previously installed some api on system but I'm just not clear on it. Can find api keys and a credential file on my system with the correct keys.
