DNS problem SERVFAIL - Unbound THROWAWAY result - Not able to create certificate
My domain is:synk.xyz
I ran this command: letsencrypt certonly --standalone -d rajan.synk.xyz
(running in docker, nginx running on host)
http-01 challenge for rajan.synk.xyz
Failed authorization procedure. rajan.synk.xyz (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://rajan.synk.xyz/.well-known/acme-challenge/RTn3jAUMfiuaPWeHUUwzZT8c9GPCdi2qKkqxGyIeOpU [13.64.69.28]: "\r\n404 Not Found\r\n<body bgcolor="white">\r\n
404 Not Found
\r\n
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 0.28.0
Hi @rajan.shah
if you use --standalone and if you have that error
That looks like a problem of your docker setup. Standalone should always work, it starts an own webserver. And Letsencrypt can connect your domain, so it's not a DNS or a firewall problem.
So your docker setup doesn't work with that new startet webserver.
I am not getting any problem in docker but when I run
 #sudo certbot certonly --standalone -d rajan.synk.xyz
Failed authorization procedure. rajan.synk.xyz (http-01): urn:ietf:params:acme:error:dns :: DNS problem: SERVFAIL looking up CAA for rajan.synk.xyz
   Domain: rajan.synk.xyz
   Type:   None
I get below error:
That's
a completely different error.
Checked your domain via https://check-your-website.server-daten.de/?q=rajan.synk.xyz there is no explicit error visible. But your name servers have problems with the EDNS-checks.
Nameserver doesn't pass all EDNS-Checks: ns1-08.azure-dns.com: OP100: SOA expected, but NOT found, NOERR expectend and NOERR found, Version 0 expectend and found, no OPT100 expected, no OPT100 found. FLAGS: SOA expected, but NOT found, NOERR expectend and NOERR found, Version 0 expectend and found. V1: ok. V1OP100: ok. V1FLAGS: ok. DNSSEC: SOA expected, but NOT found, NOERR expectend and NOERR found, Version 0 expectend and found. V1DNSSEC: ok. NSID: SOA expected, but NOT found, NOERR expectend and NOERR found, Version 0 expectend and found. COOKIE: SOA expected, but NOT found, NOERR expectend and NOERR found, Version 0 expectend and found. CLIENTSUBNET: ok.
Checking your domain via unboundtest
https://unboundtest.com/m/CAA/rajan.synk.xyz/TM4ZZBX4
there is a SERVFAIL:
Response:
;; opcode: QUERY, status: SERVFAIL, id: 37210
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
With a lot of
query response was THROWAWAY
answers.
Unboundtest uses the same configuration as the Letsencrypt - unbound instance.
There was the DNS flag day - Redirecting…
Perhaps wrong configured nameservers with EDNS problems -> now THROWAWAY results.
But I don't know if Unboundtest has changed (after the DNS flag day), so such EDNS errors now SERVFAIL errors.
PS: Checked via DNSSEC Analyzer - rajan.synk.xyz there are SERVFAILS:
ajan.synk.xyz
ns3-08.azure-dns.org returns SERVFAIL for rajan.synk.xyz/DS
ns2-08.azure-dns.net returns SERVFAIL for rajan.synk.xyz/DS
ns1-08.azure-dns.com returns SERVFAIL for rajan.synk.xyz/DS
ns4-08.azure-dns.info returns SERVFAIL for rajan.synk.xyz/DS
No DS records found for rajan.synk.xyz in the synk.xyz zone
Failed to get DNSKEY RR set for zone rajan.synk.xyz
No response from rajan.synk.xyz nameservers
Checked manual (with nslookup), no problem.
Oh, what's that:
https://dnssec-analyzer.verisignlabs.com/ has an option to show more infos:
rajan.synk.xyz
  	Checking DS between synk.xyz and rajan.synk.xyz
  	Query to ns3-08.azure-dns.org for rajan.synk.xyz/DS
  	Error querying ns3-08.azure-dns.org/2a01:111:4000:0:0:0:0:8 for rajan.synk.xyz/DS: 'IPv6 transport disabled'
  	Query to ns2-08.azure-dns.net for rajan.synk.xyz/DS
  	Query to ns1-08.azure-dns.com for rajan.synk.xyz/DS
  	Error querying ns1-08.azure-dns.com/2603:1061:0:0:0:0:0:8 for rajan.synk.xyz/DS: 'IPv6 transport disabled'
  	Query to ns4-08.azure-dns.info for rajan.synk.xyz/DS
  	Error querying ns4-08.azure-dns.info/2620:1ec:bda:0:0:0:0:8 for rajan.synk.xyz/DS: 'IPv6 transport disabled'
Looks like the name servers have ipv6, but don't answer.
PS: I've updated your topic title. Looks like a new problem. Searching this forum "unbound THROWAWAY" there is only one older topic.
For that error, the problem is that DNSSEC Analyzer doesn't support IPv6.
Compare:
http://dnsviz.net/d/dns-ipv6.mattnordhoff.net/dnssec/
(For unrelated reasons, dns-ipv6.mattnordhoff.net doesn't work reliably, but it works well enough for this demonstration.)
Thanks, good to know.
I can connect the name server via ipv6. But never seen such a list of Unboundtest errors with
Unbound can do that for multiple reasons, if the response from the nameserver is badly invalid. For example, that’s what it will log if the authoritative nameserver returns REFUSED.
In this case, Azure DNS seems to be responding to most queries for rajan.sync.xyz with a referral to itself – definitely not gonna work.
$ dig +norecurse rajan.synk.xyz @ns3-08.azure-dns.org
; <<>> DiG 9.15.1-Ubuntu <<>> +norecurse rajan.synk.xyz @ns3-08.azure-dns.org
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 15805
;; flags: qr; QUERY: 1, ANSWER: 0, AUTHORITY: 4, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4000
;; QUESTION SECTION:
;rajan.synk.xyz.                        IN      A
;; AUTHORITY SECTION:
rajan.synk.xyz.         3600    IN      NS      ns1-08.azure-dns.com.
rajan.synk.xyz.         3600    IN      NS      ns2-08.azure-dns.net.
rajan.synk.xyz.         3600    IN      NS      ns3-08.azure-dns.org.
rajan.synk.xyz.         3600    IN      NS      ns4-08.azure-dns.info.
;; Query time: 26 msec
;; SERVER: 2a01:111:4000::8#53(2a01:111:4000::8)
;; WHEN: Wed Jul 24 14:36:13 UTC 2019
;; MSG SIZE  rcvd: 180
if I run from my azure linux which is bind with synk.xyz than it get success
letsencrypt certonly --standalone -d rgs.synk.xyz
but when I run in docker than it give connection refusd
docker port
-p 127.0.0.1:81:81
-p 443:4443
-p 53:53
-p 53:53/udp \
can I run letsencrypt on another port?
No, you can’t. The use of port 80 is required by the ACME standard.
However, Certbot can listen on any port, using the --http-01-port option. That can be useful when using reverse proxying or port forwarding.
