My domain is: dashboard.metricks.nl
none.
/var/log/letsencrypt/letsencrypt.log
Fedora release 34
Strato.nl
Yes
yes, for the dns records yes.
or certbot-auto --version
if you're using Certbot):
The server works as follows:
We are running a grafana server and are trying to add SSL to this server.
dashboard.metricks.nl is a subdomain from metricks.nl that is provided from strato.
strato then sends us to our Proxmox server where let's encrypt is installed on the Virtual machine with fedora and grafana. But we are getting the error, DNS problem: NXDOMAIN looking up A for www.dashboard.metricks.nl - check that a DNS record exists for this domain; NXDOMAIN looking up AAAA for www.dahboard.metricks.nl - chhheck that a DNS record exists for this domain.
Thanks!
